Linux beginner (Questions)
ajith_jk
Newbie level 1
Newbie level 1
Well am a beginner in linux and know nothing much about it.
I have the fedora core 5 version.
I basically want to know how to mount windows using linux.
I would be obliged if you could tell me a link for linux commands.
regards,
Ajith
ivar4ever
Full Member level 3
Full Member level 3
India
excellent link for Linux Beginers
h**p://tldp.org/LDP/intro-linux/intro-linux.pdf
    ajith_jk
louisnells
Full Member level 4
Full Member level 4
To mount your windows partition under Linux you have to know the windows partition numbers (may be you can do "fdisk /dev/hdx").
Then try "mount -t vfat /dev/hdx# <mount-dir>" or "mount -t ntfs /dev/hdx# <mount-dir>". The '-t' option is most often not necessary. To mount NTFS partitions you should have special kernel module.
[/quote]
    ajith_jk
ajith_jk
Newbie level 1
Newbie level 1
hEY THANX A LOT EVERYONE................................
u04f061
Full Member level 1
i use ubuntu 6.06 nicknamed as dapper drake.
i think it is most efficient release of ubuntu and also an edgy distro.it is much easier to install even easier than win xp. it automatically mounts windows partitions to your desktop.so u do nothing.
u can get it from
www.shipit.ubuntu.com
its shipping is free ,u just need to register ,within one month u will get ubuntu cds at home. it also has too much active forum at
www.ubuntuforums.org
shaikhsarfraz
Full Member level 5
Full Member level 5
If you want to install Linux on your system you can get the book,
Linux for Beginners from Wrox Publication.
It will solve all your queries related to installlation of Linux and further operation.
Apart from that you will also get Linux Fedora 9 CD's with the books.
I am not sure whether the book is on EDA Board or not.
Thanks
Shaikh Sarfraz
sgupta_one
Newbie level 6
Newbie level 6
first you should make a directory
mkdir /mnt/win
then mount your windows partition using
mount /dev/hda1 /mnt/win
(if it is on c: drive)
you can unmount using
umount /mnt/win
you can even make it automount at startup,just add following to your /etc/fstab
/dev/hda1 /mnt/win vfat defaults 0 0
adi_gupta19
Junior Member level 1
make sure your window drive is not ntfs partitioned
ntfs partitions are not usually recognised by the linux os
and if your window partition is the first primary partition
then type
mkdir /mnt/c:
mount -t vfat /dev/hda1 /mnt/c:
for any further enquiry type your problem in
www.google.com/linux
blackdebugger
Indonesia
Hello adi_gupta19
I dont think that the latest Linux distro could not detect ntfs well. By the way, the latest linux distro supports either write and read from ntfs partition. ref: linux-ntfs.sf.net
Even today u can recover, resize and repartition ur hd even it is in ntfs.
Ragnarok83
Member level 3
Member level 3
Colombia
i recomend that when you install linux, create a FAT32 partition and then you can share information between windows and linux without problem, and for mount them go to /etc/fstab and edit it for mount them automatically on /mnt or /media you can choose, i guess. or if you put them li noauto just use the mount command.
mehboob_iiui
Full Member level 2
Full Member level 2
Rawalpindi - Pakistan
I presume you mean mounting windows partitions,
if your partitions are FAT32 it is quite simple
just type
#mount -t vfat /dev/hdaxx /mnt/abc
if they are ntfs you will not be able to access , as much as I know without external software,
check our http://linux-ntfs.sourceforge.net
onioni
Member level 1
Member level 1
For beginners, just try "hiweed", windows partitions will be mounted automatically!
check h**p://www.hiweed.com
u04f061
Full Member level 1
in ubuntu i do this.
root fdisk -l
it then displays me all the partitions of my hard drive.
then point out the partition u want to mount. then make a folder in /media directory where u want to mount partition. let u created a folder winxp and want to mount partition hda1 . then do this
root mount /dev/hda1 /media/winxp
spweda
Full Member level 3
Full Member level 3
It is no problem to mount the NTFS disk in th elinux environment. However, it is usually to munnt as read only.
