I am new to Signal Integrity simulations and just started learning HyperLynx LineSim for basic Pre-layout SI simulations. Can anybody suggest some basic tutorial or lab to start doing my basic simulations. I searched on internet and i was only able to find Linesim user guide, which is quite general and dont tell much which exact components i have to use.
One basic question about LineSim. I need to use a 50Ohm characteristic impedance ideal driver in LineSim. Which component i should use for that. I tried to put some IBIS drivers but it is really hard to understand that where i have to put 50Ohm driver impedance in those models. I also tried with .MOD models in .tech.mod library but i am unable to understand the model parameters and how to change the driving impedance to 50Ohm. Can you help
You should be able to change the sink/source impedance. If you double click on the driver/receiver, there should be an option for you to change the internal impedance.
