[SOLVED] linear regulator with high surg current
ali-libre
Junior Member level 1
witch is a better solution
1 , 2 or 3
of course 2 may not work
another question is that T2 in circuit1 are act as base current source or not
I´d say 3), because the power transistor here works like a voltage source = low impedance for surge currents.
1) is more a current source wich is high impedance for surge currents.
Klaus
Circuit 1 is unstable without additional feedback loop compensation. Circuit 2 has errors, as already mentioned. Circuit 3 needs darlington transistors or additional current gain for high output current.
Consider OP output voltage range and required supply.
to const current or to regulator...?
