Maik Vogt
Newbie level 3
- Joined
- Nov 11, 2014
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 39
Linear amplifier for ultrasonic transmitter
Hi guys,
I am trying to amplify a sine chirp signal with a frequency range of about 37-43khz which I want to use for correlation.
Prior to this I used a logic level mosfet to ampflify a square wave from a microcontroller which worked fine.
But now I want to amplify a sine signal. I tried using a TSH22 op amp that worked fine in my receiver circuit.
But it does not seem to be able to provide the necessary current for my ultrasonic transducer.
I use 24V supply voltage.
Would a TL072 op amp work?
http://pdf.datasheetcatalog.com/datasheet/SGSThomsonMicroelectronics/mXrxvrt.pdf
Or do I need to build a class A, AB, etc ampflifier using BJTs?
This is the transmitter I use:
I want to have a clean signal for correlation of multiple recievers for trilateration/multilateration.
Distance is < 1m.
Thanks!
Hi guys,
Distance is < 1m.
Thanks!
