Limitations of terrestrial UHF
AhmedGalal
Alexandria, Egypt, Egypt
Firstly I'm sorry if my question is Dump :sad: I'm not a Communication Engineer , I'm production Engineer
What are the geographical limitations of tv reception system of terrestrial UHF ?
What if I used antenna array to incrase gain ? Is that can help me receive far stations ,
Is Analog transmission has more coverage than Digital transmission
Thanks in advance
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
UHF broadcasts have slightly more snow, compared to VHF.
UHF may be processed differently inside the tv, so it may or may not be due to the higher broadcast frequency.
A good antenna does wonders for tv reception. Also the ability to aim it toward the broadcast.
Digital reception is free of snow, however its range is limited compared to analog. My digital tv goes blank if reception is weak. Or perhaps it updates the picture every few seconds.
Analog tv displays some picture from a distant weak station, even if it has a lot of snow.
chuckey
Advanced Member level 5
Southampton and holiday cottage in Wensleydale (UK
UHF transmissions are almost line off sight. To receive a distant station the first thing to do is to plot the terrain between it and you. If there is a range of mountains in between you might not get anything. Once you have established that there is line of sight, then the biggest aerial you can afford is the way to go. Elevating your aerial normally boosts the signal and gives a better line of sight.
Analogue v. digital, The transmission power is set to give equal geographic coverage, so its a bit academic.
Frank
biff44
New England, USA
yep, big antenna, really high up, no mountains in the way, and a booster amp after the antenna.
You MIGHT get some transmission off of sky bounce too, so try pointing antenna up at the sky.
vfone
Ionosphere doesn't help UHF signals to get a "sky bounce".
