Lightning Simulator Circuit
proslion
Newbie level 5
Zimbabwe
I am working on a lightning sensor. So I have to design a lightning simulator which I will use to test my sensor in the lab. The problem is where to start on the simulator circuit. So can someone help about designing a lightning simulator
Does your sensor detect radio frequency static? Or is it a photodetector?
If it detects rf, then you can produce static bursts by scratching wires together which are hooked up to a flashlight battery.
Yes it detects Radio frequency statics, I'm going to try that and observe the results. So in terms of the antenna, I was thinking of using a telescopic antenna for demonstration. Will this antenna work properly for detection of those statics.
Yes. The sparks transmit on all frequencies.
A similar experiment is described at the webpage below. They use a 9-volt battery to make sparks near an AM radio.
Thanks for the information. I have seen the experiment. I will be in touch.
There are commercial units for airborne detection and ranging of lightning strikes. The first brand was "Stormscope." There are now other brands. The literature is probably scant on technical details, but searching on Stormscope may get some useful information for you. Here is one link: **broken link removed**
Wikipedia also has a section on lightning detection (https://en.wikipedia.org/wiki/Lightning_detection). There is a brief discussion of antenna types. Reference 1 in that section looks like it may be right on topic.
John
