Library P*r*o*t*e*l 99 to D*X*P 2004
debutpic
Member level 4
Hi all
Can we use a library footprint of Protel99 to Protel DXP2004?
Frosty
Full Member level 6
EARTH
Yes
You can open 99SE libraries in DXP200x
:F
Frosty
Full Member level 6
EARTH
Can you explain the exact procedure
Procedure to open 99SE file in DXP2004 ?
Sure, no problem mate,
1. Assume that the P99SE libs have been exported from their DDB container and exist as .lib files
Start DXP2004
File,
Open,
Select PCB libray [*.pcblib; *.lib] from Files of Type drop down list
Browse to your 99SE library file for example c:\mylib.lib
Select and click open
Thats it, save as V5 file when finished editing
2. Assume that the P99SE library is a DDB container
Start DXP2004
File,
Open,
Browse to the .DDB file which has the libraries in it
You will be asked to confirm Export of DDB contents to projects
Click Yes
In the project panel your Libraries will exist in the project tree
Click to open libraries and "Save As" to move outside the project
Enjoy
:F
