To select some footprints go to:
>Place>manually
select Library in Advanced settings
select Package symbols in Placement List
Click Hide after selecting your componments
Good work.
I am not sure where exactly it is(as it has been while since i used cadence software) but there is an export library option somewhere from where you can get all your layout footprints into a library folder.
footprints for allegro pcb editor are stored in a folder called symbols.
share->pcb-?pcb_lib->symbols
however they are stored in .drf fromat and i dont know how to read them...
Use Orcad layout translator, create *.max boards in orcad with all your footprints then run the translator on them to create a PCB Editor *.brd file, then you can save the footprints as *.dra files in the correct location. There is a manual for moving from Orcad to PCB Editor, I cant find my copy and its over 3 years since I did it and I can only remember the basics above.
