module NOKIA_3310_LCD_P16
' Written by ANTON RIECKERT
' anton@riecktron.co.za
' http:'www.riecktron.co.za
' Last updated : 14 November 2008 - Added support for P16 and P18
' LCD Initialization
Sub Procedure NOK_Init(Dim Byref port as byte, Dim cs, reset_pin, sclk, dc, sda as byte)
Sub Procedure NOK_Write (Dim datas, mode as byte)
' Draws a character on screen at current possition
Sub Procedure NOK_Chr(Dim symlcd as Byte)
' Set the current position for data (0<= x <= 84, 0<= y <= 5)
Sub Procedure NOK_GotoXY(Dim x,y as byte)
' Inverts Display - Here is still a bug. It only inverst once and doesn't
' want to invert back again
Sub Procedure NOK_Invert
' Clear the LCD Data memory
Sub Procedure NOK_Clear
' Writes a string at x, y position (maks 14 char per row) (0 <= x <= 84 , 0 <= y <= 5)
Sub Procedure NOK_Out(Dim x, y as byte, Dim Byref sentance as char[14])
' Writes a string at current position
Sub Procedure NOK_Out_CP(Dim Byref sentance as char[14])
'****************************************************************************'[/color]
implements
const font5x7_1 as byte[230] = (
0x00, 0x00, 0x00, 0x00, 0x00 , ' sp
0x00, 0x00, 0x2f, 0x00, 0x00 , ' !
0x00, 0x07, 0x00, 0x07, 0x00 , ' "
0x14, 0x7f, 0x14, 0x7f, 0x14 , ' #
0x24, 0x2a, 0x7f, 0x2a, 0x12 , ' $
0xc4, 0xc8, 0x10, 0x26, 0x46 , ' %
0x36, 0x49, 0x55, 0x22, 0x50 , ' &
0x00, 0x05, 0x03, 0x00, 0x00 , ' '
0x00, 0x1c, 0x22, 0x41, 0x00 , ' (
0x00, 0x41, 0x22, 0x1c, 0x00 , ' )
0x14, 0x08, 0x3E, 0x08, 0x14 , ' *
0x08, 0x08, 0x3E, 0x08, 0x08 , ' +
0x00, 0x00, 0x50, 0x30, 0x00 , ' ,
0x10, 0x10, 0x10, 0x10, 0x10 , ' -
0x00, 0x60, 0x60, 0x00, 0x00 , ' .
0x20, 0x10, 0x08, 0x04, 0x02 , ' /
0x3E, 0x51, 0x49, 0x45, 0x3E , ' 0
0x00, 0x42, 0x7F, 0x40, 0x00 , ' 1
0x42, 0x61, 0x51, 0x49, 0x46 , ' 2
0x21, 0x41, 0x45, 0x4B, 0x31 , ' 3
0x18, 0x14, 0x12, 0x7F, 0x10 , ' 4
0x27, 0x45, 0x45, 0x45, 0x39 , ' 5
0x3C, 0x4A, 0x49, 0x49, 0x30 , ' 6
0x01, 0x71, 0x09, 0x05, 0x03 , ' 7
0x36, 0x49, 0x49, 0x49, 0x36 , ' 8
0x06, 0x49, 0x49, 0x29, 0x1E , ' 9
0x00, 0x36, 0x36, 0x00, 0x00 , ' :
0x00, 0x56, 0x36, 0x00, 0x00 , '
0x08, 0x14, 0x22, 0x41, 0x00 , ' <
0x14, 0x14, 0x14, 0x14, 0x14 , ' =
0x00, 0x41, 0x22, 0x14, 0x08 , ' >
0x02, 0x01, 0x51, 0x09, 0x06 , ' ?
0x32, 0x49, 0x59, 0x51, 0x3E , ' @
0x7E, 0x11, 0x11, 0x11, 0x7E , ' A
0x7F, 0x49, 0x49, 0x49, 0x36 , ' B
0x3E, 0x41, 0x41, 0x41, 0x22 , ' C
0x7F, 0x41, 0x41, 0x22, 0x1C , ' D
0x7F, 0x49, 0x49, 0x49, 0x41 , ' E
0x7F, 0x09, 0x09, 0x09, 0x01 , ' F
0x3E, 0x41, 0x49, 0x49, 0x7A , ' G
0x7F, 0x08, 0x08, 0x08, 0x7F , ' H
0x00, 0x41, 0x7F, 0x41, 0x00 , ' I
0x20, 0x40, 0x41, 0x3F, 0x01 , ' J
0x7F, 0x08, 0x14, 0x22, 0x41 , ' K
0x7F, 0x40, 0x40, 0x40, 0x40 , ' L
0x7F, 0x02, 0x0C, 0x02, 0x7F) ' M
const font5x7_2 as byte[225] = (
0x7F, 0x04, 0x08, 0x10, 0x7F , ' N
0x3E, 0x41, 0x41, 0x41, 0x3E , ' O
0x7F, 0x09, 0x09, 0x09, 0x06 , ' P
0x3E, 0x41, 0x51, 0x21, 0x5E , ' Q
0x7F, 0x09, 0x19, 0x29, 0x46 , ' R
0x46, 0x49, 0x49, 0x49, 0x31 , ' S
0x01, 0x01, 0x7F, 0x01, 0x01 , ' T
0x3F, 0x40, 0x40, 0x40, 0x3F , ' U
0x1F, 0x20, 0x40, 0x20, 0x1F , ' V
0x3F, 0x40, 0x38, 0x40, 0x3F , ' W
0x63, 0x14, 0x08, 0x14, 0x63 , ' X
0x07, 0x08, 0x70, 0x08, 0x07 , ' Y
0x61, 0x51, 0x49, 0x45, 0x43 , ' Z
0x00, 0x7F, 0x41, 0x41, 0x00 , ' [
0x55, 0x2A, 0x55, 0x2A, 0x55 , ' 55
0x00, 0x41, 0x41, 0x7F, 0x00 , ' ]
0x04, 0x02, 0x01, 0x02, 0x04 , ' ^
0x40, 0x40, 0x40, 0x40, 0x40 , ' _
0x00, 0x01, 0x02, 0x04, 0x00 , ' '
0x20, 0x54, 0x54, 0x54, 0x78 , ' a
0x7F, 0x48, 0x44, 0x44, 0x38 , ' b
0x38, 0x44, 0x44, 0x44, 0x20 , ' c
0x38, 0x44, 0x44, 0x48, 0x7F , ' d
0x38, 0x54, 0x54, 0x54, 0x18 , ' e
0x08, 0x7E, 0x09, 0x01, 0x02 , ' f
0x0C, 0x52, 0x52, 0x52, 0x3E , ' g
0x7F, 0x08, 0x04, 0x04, 0x78 , ' h
0x00, 0x44, 0x7D, 0x40, 0x00 , ' i
0x20, 0x40, 0x44, 0x3D, 0x00 , ' j
0x7F, 0x10, 0x28, 0x44, 0x00 , ' k
0x00, 0x41, 0x7F, 0x40, 0x00 , ' l
0x7C, 0x04, 0x18, 0x04, 0x78 , ' m
0x7C, 0x08, 0x04, 0x04, 0x78 , ' n
0x38, 0x44, 0x44, 0x44, 0x38 , ' o
0x7C, 0x14, 0x14, 0x14, 0x08 , ' p
0x08, 0x14, 0x14, 0x18, 0x7C , ' q
0x7C, 0x08, 0x04, 0x04, 0x08 , ' r
0x48, 0x54, 0x54, 0x54, 0x20 , ' s
0x04, 0x3F, 0x44, 0x40, 0x20 , ' t
0x3C, 0x40, 0x40, 0x20, 0x7C , ' u
0x1C, 0x20, 0x40, 0x20, 0x1C , ' v
0x3C, 0x40, 0x30, 0x40, 0x3C , ' w
0x44, 0x28, 0x10, 0x28, 0x44 , ' x
0x0C, 0x50, 0x50, 0x50, 0x3C , ' y
0x44, 0x64, 0x54, 0x4C, 0x44) ' z
dim
___NCS, ' CS - Chip Enable
___NRES, ' RES - Reset Input
___NSCLK, ' SCLK - Serial Clock Input
___NDC, ' DC - Data / Command
___NSDA as byte ' SDA - Serial Data Input
#IFDEF P18 THEN
Dim portaddresse as word
#ELSE
Dim portaddresse as byte
#ENDIF
portaddresse = @port
___NCS = cs
___NRES = reset_pin
___NSCLK = sclk
___NDC = dc
___NSDA = sda
#IFDEF P18 THEN
FSR0H = hi(portaddresse)
FSR0L = lo(portaddresse)
' Set initial status of LCD pins
ClearBit(INDF0,___NSCLK) ' SCLK = low
ClearBit(INDF0,___NSDA) ' SDA = low
ClearBit(INDF0,___NDC) ' DC = low
ClearBit(INDF0,___NCS) ' CS = low
ClearBit(INDF0,___NRES) ' RES = low
' Toggle LCD reset
Delay_ms(200)
Delay_ms(500)
SetBit(INDF0,___NRES) ' RES = high
SetBit(INDF0,___NCS) ' CS = high
#ELSE
FSRPtr = portaddresse
ClearBit(INDF,___NSCLK) ' SCLK = low
ClearBit(INDF,___NSDA) ' SDA = low
ClearBit(INDF,___NDC) ' DC = low
ClearBit(INDF,___NCS) ' CS = low
ClearBit(INDF,___NRES) ' RES = low
' Toggle LCD reset
Delay_ms(200)
Delay_ms(500)
SetBit(INDF,___NRES) ' RES = high
SetBit(INDF,___NCS) ' CS = high
#ENDIF
NOK_Write(0x21,0) ' Extended commands
NOK_Write(0xc5,0) ' LCD Vop
NOK_Write(0x06,0) ' Temp coef
NOK_Write(0x13,0) ' LCD Bias 1:48
NOK_Write(0x20,0) ' Standard commands
NOK_Write(0x0c,0) ' Normal Mode
' Clear and position at top of LCD
NOK_Clear
NOK_GotoXY(0,0)
End Sub
Dim i, k as byte
#IFDEF P18 THEN
' Pull DC high for DATA or low for COMMAND
If (TestBit(mode,0) = 1) then SetBit(INDF0,___NDC) End If
If (TestBit(mode,0) = 0) then ClearBit(INDF0,___NDC) End If
' Clock in 8 bits of data - Highst bit first
For i = 8 to 1 Step -1
k = i - 1
If TestBit(Datas,k) = 0 then ClearBit(INDF0,___NSDA) ' SDA = low
else SetBit(INDF0,___NSDA) ' SDA = high
End If
SetBit(INDF0,___NSCLK) ' SCLK = high
Next i
#ELSE
If (TestBit(mode,0) = 1) then SetBit(INDF,___NDC) End If
If (TestBit(mode,0) = 0) then ClearBit(INDF,___NDC) End If
k = i - 1
If TestBit(Datas,k) = 0 then ClearBit(INDF,___NSDA) ' SDA = low
else SetBit(INDF,___NSDA) ' SDA = high
End If
SetBit(INDF,___NSCLK) ' SCLK = high
Next i
#ENDIF
End Sub
Dim l, m as Byte
NOK_Write(0x00,1) ' Space between characters
If (symlcd < 78) then
For l = 1 to 5
m = (symlcd - 32)
m = m * 5
m = m + l
m = m - 1
NOK_Write(Font5x7_1[m],1)
Next l
End If
If (symlcd > 77) then
symlcd = symlcd - 46
For l = 1 to 5
m = (symlcd - 32)
m = m * 5
m = m + l
m = m - 1
NOK_Write(Font5x7_2[m],1)
Next l
End If
End Sub
Dim n, o as Byte
n = x
o = y
SetBit(n,7)
SetBit(o,6)
NOK_Write (o,0)
NOK_Write (n,0)
End Sub
NOK_Write(0x0D,0)
End Sub
Dim p, q, r as Byte
#IFDEF P18 THEN
ClearBit(INDF0,___NSDA) ' SDA = low - Data bit is low
SetBit(INDF0,___NDC) ' DC = high - Data mode
ClearBit(INDF0,___NCS) ' CS = low - Chip Enable
For p = 1 to 6 ' for 6 rows
For q = 1 to 84 ' for 84 colums
For r = 1 to 8 ' for 8 loop (8 bits)
ClearBit(INDF0,___NSCLK) ' SCLK = low - Serial Clock Input
SetBit(INDF0,___NSCLK) ' SCLK = high - Serial Clock Input
Next r
Next q
Next p
SetBit(INDF0,___NCS) ' CS = high - Chip Enable
NOK_GotoXY(0,0)
#ELSE
ClearBit(INDF,___NSDA) ' SDA = low - Data bit is low
SetBit(INDF,___NDC) ' DC = high - Data mode
ClearBit(INDF,___NCS) ' CS = low - Chip Enable
ClearBit(INDF,___NSCLK) ' SCLK = low - Serial Clock Input
SetBit(INDF,___NSCLK) ' SCLK = high - Serial Clock Input
Next r
Next q
Next p
SetBit(INDF,___NCS) ' CS = high - Chip Enable
NOK_GotoXY(0,0)
#ENDIF
End Sub
Dim v as byte
NOK_GotoXY(x,y)
For v = 0 to length(sentance) - 1
NOK_Chr(sentance[v])
Next v
End Sub
Dim v as byte
Next v
End Sub
end.
