eklikeroomys
Full Member level 3
- Joined
- Oct 11, 2010
- Messages
- 150
- Helped
- 40
- Reputation
- 80
- Reaction score
- 38
- Trophy points
- 1,308
- Location
- South Africa
- Activity points
- 2,132
Halo,
I am trying to define a simple DFF in a Synopsis Liberty file used for synthesis. I want to define the cell using the statetable group of the .lib format because I want to define some more complex cells later on when I am familiar with the syntax.
I have written the code for defining the simple DFF but RTL compiler recognizes the DFF as unusable..
I cant find any faults in my coding, is there some switch that I need to set in RTL Compiler or should I add something to the .lib file?
Thank you!
Correction: I am trying to define a simple TFF (Toggle Flip Flop).
Thank you!
