Register Log in
Level converter devices
joniengr
Full Member level 3
I am looking for level converters from 3.3 V to 1.8 V. The differential clock signals I am dealing with are of frequency 500 MHz. There are two clocks i.e. four differential pairs. Any suggestions how to find level converter devices ?
KlausST
Super Moderator
Staff member
* 500MHz 3.3V level differential signals are not very usual. Please confirm. Maybe they are LVDS or any other IO standard.
* Then look at the receiver IC datasheets for the level requirements (common mode, differential mode, hysteresis) and max allowed input levels.
* also check about characteristic line impedance requirements and the use of termination
In simplest case you may just connect them
Next simple is that you need resistive voltage dividers. (values may depend on characteristic impedance)
Maybe you need true level converters. A search at a distributor should work. There you may also find manufacturer names for level converters. Then visit the manufacturer internet site for additional informations and selection tools.
Klaus
Toggle Sidebar
Design Fast
