Leonardo Spectrum compilation of CoreGenerator blocks
AMCC
Member level 2
Member level 2
leonardo spectrum ngc file
In LeonardoSpectrum when doing EDIF2NGd command the fowlling message appears :
ERROR:NgdBuild:604 - logical block 'I0' with type 'count2' could not be
resolved. A pin name misspelling can cause this, a missing edif or ngc file, or the misspelling of a type name. Symbol 'count2' is not supported in target 'virtex2p'.
when I use CoreGen on HDLDesigner.
Does any one have experienced some similar problem?
Thak you for your attention.
AMCC
What is count2 in your design?
If it is module generated by CoreGen you have to load it in LS with command:
read_coregen "fullpath/count2.edn"
Ace-X.
when you use coregen in HDL designer,
you must select the module, and set the prioperty.
and control LS using the edn file WHEN synthesizing.
good luck
