LEDs not working
drew2468
Newbie
I’m working on making grow lights. I mounted the LEDs to the starboards, checked the LEDs with my multimeter, all good. I mounted the starboards to my panel, tested the LEDs again, all good. I soldered the wires connecting the starboards and tested the connections, all good. I connected the LEDs to my driver, plugged it in, and they all worked. A day later, I plug it in again, and now only four LEDs are working—two on one end and two on the other, all the ones in between are out. I used my multimeter to test all the LEDs with the diode tester and they still work. What am I missing?
LEDs: Forward Current: 350 mA; Forward Voltage: 2.2 V; Power Rating: 2 W. I have 14 LEDs in series. Driver is 350mA constant current 28-100VDC 35 Watt
KlausST
Super Moderator
Staff member
you have 14 LEDs in series ....and only 2+2 work?
Show photos of your wiring. And tell us which is which (input output, cathode, anode,...)
Then we can tell what measurement you should do to debug the circuit.
Best: Use a picture with good resolution, reduce the color qualitiy to get less than 1MB, show them as thumbnail.
Klaus
Audioguru
Advanced Member level 5
Toronto area of Canada
The little stars do not provide enough cooling for the LEDs in between the ends when the current is full blast.
MichalP
Junior Member level 1
Krakow
You should add resistors to it if you do not want to burn diodes
