If you know basic circuit theory, then the answer is readily a yes. You can think of electrical current like water flowing in a pipe... except that its electrons flowing through a conductor (wire). If you have 3 devices in series, the same amount of water (current) will flow through the series parts. So you now know that each string of series devices will draw 60 mA. So, if you have multiple strings in parallel, each will draw 60 mA... so, 60+60+60+60 = 60*4 = 240 mA, total.
The easiest way to remember is that items in series see the same current (water flows through). When you have items in parallel, the current (water) divides and a portion goes down each parallel path. The amount of current going down each parallel path depends on the resistance/impedance of each path... less resistance, more water/current; more resistance, less water/current.
