LED luminous intensity and angle of illumiation
eem2am
Banned
Please see this datasheet for a 3.7W White LED.
***DATASHEET FOR LUXEON III EMITTER LED
https://www.philipslumileds.com/pdfs/DS45.PDF
On page 14, you can see that although the LED emits light over a 180 degree angle, the intensity drops off as the angle increases.
Are there any White power LEDs that do not suffer such reduction of luminous intensity with angular displacement ?
That is, is there such thing as a white power LED which emits at equal intensity in all directions ? (obviously excluding behind the LED itself).
P
pauloynski
As far as I know there isn´t such a led. The viewing angle is dependent on the shape of the lens in front of the emitter.
Audioguru
Advanced Member level 5
Toronto area of Canada
The Luxeon III has an angle of 100 degrees where its luminous intensity is half of its on-axis peak.
Your vision's response to brightness is logarithmic so half is only a small decrease.
eem2am
Banned
thankyou paloynski and Audioguru
paloynski:-
do you believe it is possible to just make the lens shaped such that the LED emits equal intensity in all directions?
