LED Driver 110Vac input
gilbertomaldito
Full Member level 3
led from 110v ac
I just have a question regarding the Vbuck which is drived into the LED from the AC input of 110Vac. I know AC input will pass Bridge Rectifier and then a large capacitor, to make this dc. Because driving LED must be DC. but since AC peak will be 155V (110 x sqrt(2)), does this mean DC will have a maximum value of 155V?
Is my understanding right?
If yes, how can you possibly make the current constant?
reference - National Semiconductor Triac Dimmable LED Driver
driving leds 110vac
andrew_matiga said:
... since AC peak will be 155V (110 x sqrt(2)), does this mean DC will have a maximum value of 155V?
In principle, yes. The US standard now is 115Vac, which results in a peak voltage of 163Vdc, and with a tolerance of +10%, it can nearly go up to 180Vdc !
An AC capacitor in front of the bridge rectifier limits the current. An additional series resistor is necessary to limit the inrush current following switching-on.
____
BTW: Such questions (which have nothing to do with Analog IC Design & Layout) should better be asked .
