LED blinking program help on c program
vead
Full Member level 5
Full Member level 5
india
HI
I wrote code for LED blinking
LED blinking c code
start
turn ON LED
wait for some time (delay )
turn OFF LED
include<regx51.h>		        // header file for 8051
include<delay.h>				// header file for delay
#define LED_ON  00000001		// LED ON
#define LED_off 00000000        // LED OFF
void main()					   //main function starts
while (1)				       //infinite loop
setb P1_1=00000001;
delay (1000);
setb P1_1=00000000;
there is no error but I am not sure that code will be work ?
"LED" - 0 Error(s), 2 Warning(s).
You are also not using the #defines you added. You don't have to to use them but if you don't you can remove both the lines.
The problem Easyrider83 pointed out is that without the extra delay you turn the LED off then immediately on again as the loop repeats. It will be so fast that you won't be able to see the LED turn off and it will appear to be on all the time.
Brian.
How can i coding,
when 1st switch press 1st led off 2nd led on, again 1st switch press 1st led on 2nd led off.
when 2nd switch press 1st led off 3rd led on, again 2nd switch press 1st led on 3rd led off.
this like coding....
another delay after "setb P1_1=00000000;" missed
Now
setb P1_1=00000001;
delay (1000);
setb P1_1=00000000;
delay (1000);
Is it right ?
Brian.
when does we define port pins?
Like this. #define is used to create aliases.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
include<regx51.h>
include<delay.h>
#define LED P1_1
#define LED_ON  1
#define LED_off 0
void main()
    while (1)
        LED = LED_ON;
        delay (1000);
        LED = LED_OFF;
        delay (1000);
Miss # on includes!!!
Which the compiler used???
Keyl uVision C Code:
#include<regx51.h>
//#include<delay.h>    // I dont have it!!!
#define LED 		P1_1
#define LED_ON	        1
#define LED_OFF	0
void delay(void)			// make it, because I dont have delay.h lib
	unsigned int i;
	for (i = 0; i < 40000; i++)
void main()
	P0 = 0x00;
	P1 = 0x00;
	P2 = 0x00;
	P3 = 0x00;
	while (1)
		LED = LED_ON;
		delay();
		LED = LED_OFF;
		delay();
#include<regx51.h>
#define LED 		P1_1
#define LED_ON	        1
#define LED_OFF	0
	unsigned int i;
void main()
	P0 = 0x00;
	P1 = 0x00;
	P2 = 0x00;
	P3 = 0x00;
	while (1)
		LED = LED_ON;
		delay();
		LED = LED_OFF;
		delay();
what is meaning of following line
unsigned int i;
what is i and 40000 ?
It is a code to generate delay. i is an unsigned integer type variable and so it can hold values from 0 to 65535. In the for loop i is incremented from 0 to 39999 with a step of one. So the for loop executes 40000 times.
unsigned int i;
"i" is a variable used in FOR loop .. Since FOR loop requires variable in it Syntax, "i" is used here .. 40000 is the number of times the loop is going to be repeated, since "i" is an unsigned int which ranges from 0 to 65535, here 40000 is used which is well under the range ..
It is correct!!!
Because i dont have the lib delay.h to call a delay (1000) function in my sorce code!!!
It is correct!!!
If LED is connected with switch
when switch is on , Led will ON
wait
when switch is off , LED will OFF
 #define LED 		P1_1
#define LED_ON	        1
#define LED_OFF	0
#define switch     P1_2
#define switch_ON
#define switch_OFF
void delay(void)			//
	unsigned int i;
void main()
	P0 = 0x00;
	P1 = 0x00;
	P2 = 0x00;
	P3 = 0x00;
	If  (switch_ON )
		LED = LED_ON;
		delay();
		else (switch_OFF)
		LED = LED_OFF;
		delay();
