hithesh123
Full Member level 6
What is the leakage saturation current for 2n2222.
The Is i'm talking about is the one used in
Vbe = Vt ln(Ic/Is) equation.
it's a purely theoretical value, any value between 1fA and 1pA would do: the calculated Vbe changes by some Vt, i.e. it is unpredictable like in real life ;-)
Yes, I didn't notice the schematic. If you don't need to achiecve an exact bias point, connecting R1 between base and collector can be a simple solution.About your circuit: the operating point is totally dependent on the hfe of Q1 --> it's a bad biasing method.
Supposing you know exactly the hfe (for that operating current) you can write:
hfe*(Vcc - (Vbe + Ic*R3))/R1 = (Vcc - Vc)/R2
Not at all for the present circuit. It's only useful with a voltage divider bias circuit. But it reduces the voltage gain and increases linearity, which can be a sufficient reason to use it.Doesn't the emitter degeneration resistor help?
