leading edge vs trailing edge
reyge
Member level 4
What is the leading edge and trailing edge of the clock?
Thanks!
ei thanks.. but i have already looked at it.
....... ____..........____
.___|........|____|
......a.......b.......c
Assuming that the straight lines represent the clock, which is the leading edge? a , b, or c?
how about the trailing edge?
You should say positive edge (a,c) and negative edge (b)
Generally Transition fro low to high (a, c) is called leading edge and transition from high to low (b) is called trailing edge. I am not aware of any exception to this rule though.
according to wikipedia ...
"The terms front edge or leading edge, and back edge or trailing edge describe the related position of edges in a clock cycle. A leading edge can be a falling edge."
