I normally use Sn63 and/or Sn62 for soldering with iron temperature around 320 C. Both solders have lead i.e., Pb. I am wondering if I can use leadfree solder with the same soldering station which goes up to 360 C ? Which leadfree solders are more common ?
Many electronics use solder as the “glue” to attach components to circuit boards. Whether lead-free or lead solder, the function is the same. Lead-free and lead solder do perform the same function. However, different products and applications will use different solders.
-Lead-free solder features higher melting point than lead solder.
-Lead-free solder features worse wettability than lead solder.
