abhinand rd
I am going to design a battery charger for lead acid batteries of 48V and around 40A(around 2kW).
the circuit consists of diode bridge rectifier, followed by booster PFC and then a full bridge converter.
although I have tested these converters operating at less than 100kHz. The magnetic components (Inductor and transformer) were designed around these frequencies.
Now I want to reduce the size of the charger. I want to go upto MHz operation in order to reduce the size of the magnetic components , thereby reducing the size of overall charger(increasing power by weight ratio). I would like to know what are the problems I need to address if I go for Mhz operation? or for starters is it even really possible to go Mhz operation without increasing losses significantly. Also at MHz operation , What about the EMI problems? what will be the necessary design to take care for EMI at this frequency? All I want to do is to reduce the size of the charger.. Kindly provide me some inputs regarding this. Thanking you in anticipation.
