LDR and RTD to ADC of microcontroller
fireball003
Full Member level 3
ldr microcontroller
How would I connect LDR or RTD to the ADC port of my microcontroller ?
Would I connect in two ADC pins dirtectly?
Or i would have to follow a circuit diagram?
What is the main logic?
Please explain and upload circuit diagram if there any.
Thanks in advance.
ldr to adc
No you can not connect an RTD not an LDR directly to a microcontroller pin. These two sensors are mere temperature dependemt resitors; meaning that the value of their resistance varies with temperature. You need to convert this variable resistance to a voltage so that it can be sensed with an ADC. The best strategy is to supply them with a constant current (from a current source) and measure the developed voltage. Feed this voltage to the ADC to convert to digital form.
Hope this helps.
Good luck
how do i interface ldr to microcontroller
suppose I use 5v current from by board as constant current source then if I connect LDR with that source and ADC pin , then is it not correct?
Else what circuit do I need?
Thank you.
microcontroller implementation of rtd
You could take a look at the 8051-based microcontrollers made by Analog Devices for example the ADuC834 has facilities to directly interface to RTD devices.
Took a look at **broken link removed**
try connecting it using the inbuilt ADC pins (Eg: PORTA for ATmega16),choose appropriate mux channel and program d algorithm using AVRSTUDIO GCC compiler,output digital signals can be taken from other ports.Watch out videos of tishitu electronics on youtube.
Added after 2 minutes:
It's better to use ADC chips than to use the Adc pins of uC
A Simple arrangement to use these sensors with an ADC is to form a voltage divider circuit. This can be done very easily by connecting the LDR in series with a fixed resistor. Since the two resistors (fixed resistor and LDR) are forming a voltage divider circuit there will be a certain voltage drop across each resistor.
As the resistance of the LDR varies with the intensity of the incident light there the voltage drop across it will also vary.
This change of voltage can be sensed by any ADC wheather it is a built in ADC inside a controller or an independent ADC.
The circuit diagram of a simple circuit that explains the above arrangement is added an an attachment.
One another alternate way for LDR is use comparator with 0.6v internal ref on comparator - pin & at +pin give LDR voltage to compare the light intensity for Light.
Regards
Chanchal Chauhan
