snang
Newbie level 6
Hello,
I have a question regarding the tapeout of a Low Dropout Regulator (LDO), so I’m posting here. I recently completed the tapeout of an LDO and am currently testing it by mounting the chip on a PCB. However, the regulation function of the LDO is not working properly.
When I test under light load conditions, the regulation seems to work well. But under heavy load, the regulation does not function correctly. Another issue is that other samples seem to regulate properly, unlike this one.
As mentioned above, I'm not fully confident that the LDO is operating correctly. Since this is my first tapeout, I'm seeking advice. What are some effective ways to verify whether the LDO is functioning properly?
Thank you.
Thank you.
