Vitor Przedzmirski
Hello guys, I appreciate very much If you could help me. I can't understand the following:
I know that the dropout voltage of an LDO is related to the minimum input voltage necessary to maintain regulation. So, If a datasheet says the dropout for a specific regulator is 100mV, and the output voltage is 3.3V, I should get 3.3V with a minimum 3.4V , right?
The specific point that I cannot understand yet is the relation between the minimum input voltage and the dropout voltage. Example:
The TI LM3940 LDO has an input voltage range of 4.5 - 5.5V, and there is a note saying:
"Because the LM3940 is a true low dropout regulator, it can hold its 3.3-V output in regulation with input voltages as low as 4.5 V."
Based on this information, I can conclude that I should have at minimal 4.5V in my input to get 3.3V at the output.
But, looking at the Electrical Characteristics Table, one can see the defined Dropout Voltage, that is typically 0.5V with maximum load. In this case, I understand that with 3.8V I could still regulate the output.
So, how come the two values can be so different? I'm trying to design an LDO and I'm stuck with this concepts.
For the dropout voltage, I am considering the differential voltage Vin-Vo when the regulated output drops 100mV (commonly used condition test in TI datasheets).
So, at last, based in what information I may decide my input voltage range?
Thanks in advance
Link for the LM3940 datasheet: https://www.ti.com/lit/ds/symlink/lm3940.pdf
Thanks in advance
