lcd with pic c compiler(ccs)
chancelier
Junior Member level 1
tunisia
hi all
i am interfacing an lcd and a keypad with pic 16F877;
my programming language is pic c compiler
i want to know how to define connections between the PIC and the LCD in the C code
in mikroC it is done as shown below
/ LCD module connections
sbit LCD_RS at RB2_bit;
sbit LCD_EN at RB3_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISB2_bit;
sbit LCD_EN_Direction at TRISB3_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
// End LCD module connection
how is that done in CCS??[/quote]
When you create a new project you have a tab includes LCD conections.
There you can define the pins of your LCD.
Regards,
Bruno
You can include flexLCD.c driver file, all the parameters are defined in this file you dont need to define it seperately in your code.You can also change pin configuration as you want.
