lcd screen flickering???
buts101
Full Member level 3
Hello EDAians,
I have one patient monitor from Schiller. The day i switched on, the color lcd screen began to flicker...continuous..but i could recognize the background. I charged the internal battery for 4 hrs. Again i switch on, it worked for 5 minutes with clear view...but again the lcd began to flicker...
Sometimes the screen goes black...sometimes its goes white...the band of color flickers...i.e. there is some problem with the lcd screen.
Therefore my question is: What may be the problem...how can i make it work properly. OR last choice is to return to the schiller and make them to mend the problem.
Best Regards,
Buts101
U have not mentioned that is that Monitor is working perfect with mains.If so then there may be problem in battery section.U have to return it to Schiller.
    buts101
hello there,
The monitor is not working properly with main. I will open it to see if there is problem with battery section.
thank you
Buts101
If Monitor is not working on main then there may be problem of connection between Mother board and LCD
