Ernestas
Hello, im trying to make autofeeder for my fishes. I want to make PIC16F628A to work similiar to 555 timer, but with LCD and PWM for food drop rate. So far i made this code
The problem is that i get hour value -33. Where did i made mistake in code? Thank you.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 // LCD module connections sbit LCD_RS at RB4_bit; sbit LCD_EN at RB5_bit; sbit LCD_D4 at RB0_bit; sbit LCD_D5 at RB1_bit; sbit LCD_D6 at RB2_bit; sbit LCD_D7 at RB6_bit; sbit LCD_RS_Direction at TRISB4_bit; sbit LCD_EN_Direction at TRISB5_bit; sbit LCD_D4_Direction at TRISB0_bit; sbit LCD_D5_Direction at TRISB1_bit; sbit LCD_D6_Direction at TRISB2_bit; sbit LCD_D7_Direction at TRISB6_bit; // End LCD module connections short hour; short minutes; char txtVal[] = "Hours :" ; char txtMin[] = "Minutes :" ; char txt1[] = "Put hours"; char txt2[] = "Put minutes"; char txt3[5] = ""; char txt4[5] = ""; int Menu = 1; void main() { TRISA = 0b10000000; TRISB = 0b10000000; PORTA = 0b00000000; PCON = 0b00001000; CMCON = 0b00000111; Lcd_Init(); // welcome message Lcd_Cmd(_LCD_CLEAR); Lcd_Cmd(_LCD_CURSOR_OFF); Lcd_Out(1, 3, "Hello"); delay_ms(10000); Lcd_cmd(_LCD_CLEAR); while(RA2 != 1 ){ //RA2 start button switch(Menu){ // Hour set in case : 1 case 1: while(Menu == 1){ ShortToStr(hour, txt3); Lcd_Out(1, 1, txtVal); // text: "Hours :" Lcd_Out(2, 1, txt3); // show hour value // Increment hour value by 1 until max 12hours if(RA7==1){ hour++; if(hour==12){ hour = 0;} }; // Change case 1 menu to case 2 menu if(RB7 == 1){ Menu++; if(Menu == 3){ Menu = 1; }; }; }; // Minutes set case : 2 case 2: while(Menu == 2){ ShortToStr(minutes, txt4); Lcd_Out(1, 1, txtMin); // Text "Minutes :" Lcd_Out(2, 1, txt4); // Show minutes value // Increment minutes value by 1, until 59 if(RA7==1){ minutes++; if(minutes==59){ // switch back to 0 minutes = 0;} ;} // Change case 2 menu to menu 3 PWM if(RB7 == 1){ Menu++; if(Menu == 3){ Menu = 1; }; }; } }; }; }
