LCD Not working 18f4620 C18
xabia
Newbie level 3
hi all i am using c18 picdem z lcd18
i cant get my lcd working display out
i had do a online search but simply cant work
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
#include <p8h>
#include <portb.h>
#include <delays.h>
#pragma config OSC = XT
#pragma config WDT = OFF
#pragma config LVP = OFF
#pragma config DEBUG = ON
#pragma config PBADEN   =   OFF // PORTB<4:0> pins are configured as digital I/O on Reset)
#define TRIS_RW  TRISDbits.TRISD5       /* TRIS for RW */
#define TRIS_RS  TRISDbits.TRISD4       /* TRIS for RS */
#define TRIS_E   TRISDbits.TRISD6       /* TRIS for E  */
#define RW_PIN   LATDbits.LATD5         /* PORT for RW */
#define RS_PIN   LATDbits.LATD4         /* PORT for RS */
#define E_PIN    LATDbits.LATD6         /* PORT for E  */
#define DB7 LATDbits.LATD3
#define DB6 LATDbits.LATD2
#define DB5 LATDbits.LATD1
#define DB4 LATDbits.LATD0
// PORTD0 - DB4
// PORTD1 - DB5
// PORTD2 - DB6
// PORTD3 - DB7
// PORTD4 - RS
// PORTD5 - RW
// PORTD6 - EN
#define SWITCH PORTBbits.RB4
#define SWITCH_1 PORTBbits.RB5
#define LED1 PORTAbits.RA0
#define LED2 PORTAbits.RA1
void lcd_send(far rom char *str);
void delay_20us(unsigned int);
void sendChar(unsigned char);
void clr_screen(void);
void clr_scr(unsigned char);
void send_cmd(unsigned char, unsigned char);
void welcome_title(void);
void send_lcd(unsigned char, unsigned char);
void write_data(far rom char *str, unsigned char);
void lcd_init(void);
void line_no(int);
void nop(void);
void clear_lcd(int);
void latch_E(void);
void delay_ms(unsigned int duration);
void display_lcd(void);
 /* global variables */
void main(void)
    INTCON2bits.RBPU=0; //Enable pull up for PB
    ADCON1=0x0f;            //Digital output
    LATB=0b00000000;        //Clear portb
    LATA=0b00000000;        //Clear porta
    TRISB=0b00110000;       //PORTB BIT4 and 5 AS INPUT, THE OTHERS ARE OUTPUT
    TRISA=0b00000000;       //PORTA OUTPUT, LED
    TRISD=0x00;         //PORTD is output, LCD
    TRISE=0x00;         //PORTE PSP not active
    LATD=0x00;
    // initialisation start
    Delay10TCYx(200);
    lcd_init();
    delay_ms(15);
    //initialisation end
    welcome_title();
while(1)
    if(SWITCH==0 & SWITCH_1==0)
        //LED1=0, LED2=0;       //Clear both LED
        LATA = 0x00;
    else if(SWITCH==0) //RB4 button
        //LED1=1, LED2=0;   //RA0 LED true
        LATA = 0x01;
        clr_scr(3);
    else if(SWITCH_1==0) //RB5 button
            //RA1 LED true
        LATA = 0x02;
        write_data("AA", 1);
void lcd_init(void) // 4bit mode
    //function set
    LATD=0b00000000;
Delay10TCYx(500);
    send_cmd(0b00110000, 0);
Delay10TCYx(500);
Delay10TCYx(500);
    send_cmd(0b00110000, 0); // 2 lines, 5x8 dots
Delay10TCYx(500);
    // display on/off control
    send_cmd(0x28, 0);
    //send_cmd(0b11100000, 0); // Display on, cursor on, blink off
    send_cmd(0x0F, 0); // Display on, cursor off, blink off
    // Entry mode
    send_cmd(0x01, 0);
    send_cmd(0x0C, 0);// increment mode, shift off
void enable(void)
  E_PIN = 1;
  Delay10TCYx(1);
  E_PIN = 0;
void send_cmd(unsigned char b, unsigned char c)
    unsigned int tempdata=b;
    RS_PIN = c; //Command mode = 0
                //To write address = 1
    LATD = ((LATD & 0xF0) | ((b >> 4) & 0x0F)) ;
    latch_E();
    delay_ms(10);
  int index = 0;
  while (str[index] != '\0')
     sendChar(str[index]);
     index++;
  int index = 0;
    //for (index=0; index<16; index++)
    while (index != 16)
        sendChar(' '); // write blank
        index++;
void clr_scr(unsigned char b)
    unsigned char index =0;
    //send_lcd (0x80,0);
    if ((b == 1) || (b == 3))
        line_no(1);
        while (index != 16)
            index++;
    if ((b == 2) || (b ==3) )
        //send_lcd (0xC0,0);
        line_no(2);
        index=0;
        while (index != 16)
            index++;
void sendChar(unsigned char b)
     RS_PIN = 1;
     DB7 = (b >> 7) & 1;
     DB6 = (b >> 6) & 1;
     DB5 = (b >> 5) & 1;
     DB4 = (b >> 4) & 1;
     latch_E();
     DB7 = (b >> 3) & 1;
     DB6 = (b >> 2) & 1;
     DB5 = (b >> 1) & 1;
     DB4 = (b & 1);
     latch_E();
     Delay10TCYx(80);
void line_no(int b)
    if (b == 2)
      send_lcd(0b11000000,0); //1100 0000 - move cursor to 2nd line
    else
      send_lcd(0b10000000,0); //1000 0000 - move cursor to 1st line
void latch_E(void)
    E_PIN=1;
    Delay10TCYx(1);
    E_PIN=0;
 /* write data on lcd */
void send_lcd(unsigned char b,unsigned char rs_con)
    unsigned int tempdata = b;
    RS_PIN = rs_con;   // set RS
                        //0 = set address
                        //1 = write data
    RW_PIN = 0;    // clear RW - write mode
    //DelayFor18TCY();
    latch_E();
    LATD  = (LATD & 0xF0) | (tempdata & 0x0F);
    Delay100TCYx(2);
    latch_E();
    Delay1KTCYx(2);      // alternate to check busy flag.. if lcd doesnt work properly, inc/dec this delay
/* Welcome*/
    unsigned char index;
    unsigned char a[16] = "Hello";
    unsigned char b[16] = "123";
    index=0;
    line_no(1);
    while (a[index] != '\0')
       send_lcd (a[index],1);
       index++;
    line_no(2);
    index=0;
    while (b[index] != '\0')
        send_lcd (b[index],1);
       index++;
void write_data(far rom char *str, unsigned char c)
    index =0;
    if (c == 2)
        clr_scr(2);
        line_no(2);
    else
        clr_scr(1);
        line_no(1);
       send_lcd (str[index],1);
       index++;
void delay_ms(unsigned int duration) // delay in miliseconds for 4.0MHZ crystal
    unsigned int i;
    for(;duration!=0;duration--)
        for(i=0;i<=50;i++)
            _asm
                nop
                nop
                nop
            _endasm
        _asm
            nop
            nop
        _endasm
void nop(void)
        _asm
            nop
        _endasm
void delay_20us(unsigned int duration) // delay in 20u for 4.0MHZ crystal
    unsigned int i;
        _asm
            nop
        _endasm
Attached is my datasheet for the LCDView attachment LCD.pdf
Appreciate your help.
thx
bigdogguru
Administrator
Southwest, USA
Does the LCD display anything at all, black boxes perhaps?
BigDog
xabia
Newbie level 3
yes it is showing when i connected it to the Vo
bigdogguru
Administrator
Southwest, USA
Vo is the contrast control.
You should have Vo attached to the wiper arm of a 10KΩ pot with the other two leads of the pot attached to Vdd and Vss.
Is that the way it is configured?
The black boxes indicate the LCD was not properly initialized.
BigDog
xabia
Newbie level 3
yes i have a trimmer from 10k to 20k
yeah i think i didn't initialize it
but i am struck on getting it work
bigdogguru
Administrator
Southwest, USA
I believe one issue is your sendchar() routine:
     RS_PIN = 1;
     DB7 = (b >> 7) & 1;
     DB6 = (b >> 6) & 1;
     DB5 = (b >> 5) & 1;
     DB4 = (b >> 4) & 1;
     latch_E();
     DB7 = (b >> 3) & 1;
     DB6 = (b >> 2) & 1;
     DB5 = (b >> 1) & 1;
     DB4 = (b & 1);
     latch_E();
     Delay10TCYx(80);
The most significant nybble (upper four bits) first, followed by the least significant nybble (lower four bits).
You might try something like the following routines:
//LCD Control pins
#define rs LATA.F0
#define rw LATA.F1
#define en LATA.F2
//LCD Data pins
#define lcdport LATB
void lcd_ini();
void dis_cmd(unsigned char);
void dis_data(unsigned char);
void lcdcmd(unsigned char);
void lcddata(unsigned char);
void main(void)
	unsigned char data0[]="EngineersGarage";
	unsigned int i=0;
	TRISB=0;			// Configure Port B as output port
	LATB=0;
	Delay_ms(100);
	lcd_ini();			// LCD initialization
	while(data0[i]!='\0')
		dis_data(data0[i]);
		Delay_ms(200);
		i++;
void lcd_ini()
	dis_cmd(0x02);		// To initialize LCD in 4-bit mode.
	dis_cmd(0x28);		// To initialize LCD in 2 lines, 5x7 dots and 4bit mode.
	dis_cmd(0x0C);
	dis_cmd(0x06);
	dis_cmd(0x80);
void dis_cmd(unsigned char cmd_value)
	unsigned char cmd_value1;
	cmd_value1 = (cmd_value & 0xF0);	// Mask lower nibble because RB4-RB7 pins are being used
	lcdcmd(cmd_value1);			// Send to LCD
	cmd_value1 = ((cmd_value<<4) & 0xF0);	// Shift 4-bit and mask
void dis_data(unsigned char data_value)
	unsigned char data_value1;
	data_value1=(data_value&0xF0);
	lcddata(data_value1);
	data_value1=((data_value<<4)&0xF0);
void lcdcmd(unsigned char cmdout)
	lcdport=cmdout;		//Send command to lcdport=PORTB
	rs=0;
	rw=0;
	en=1;
	Delay_ms(10);
	en=0;
void lcddata(unsigned char dataout)
	lcdport=dataout;	//Send data to lcdport=PORTB
	rs=1;
	rw=0;
	en=1;
	Delay_ms(10);
	en=0;
Personally I prefer to use the busy flag, but the appropriate delay will suffice.
BigDog
