[51] lcd interfacing with AT89C52 microcontroller
sugandha_
Newbie level 5
When I connect my LCD to AT89C52, it's just showing a blank screen.
I have connected pin3 of lcd irectly to 5V and have also tried it with potentiometer but still getting the same results.
All the data lines of lcd are high, when checked with multimeter.
I'm using JHD162A lcd screen.
The code is working fine in proteus.
I'm attaching the hardware connections and code below.
referred link: https://okashtein.wordpress.com/2013/03/22/calender-asm-51/
LCD		EQU		P0
SECS	EQU		30H
MINS	EQU		31H
HRS		EQU		32H
YRS		EQU		33H
MONS	EQU		34H
DAYS	EQU		35H
RS		BIT		P2.0
E		BIT		P2.1
		ORG 	0H
		AJMP	MAIN
		ORG 	30H
MAIN:	ACALL 	lcdInit1
		ACALL	setTime
		ACALL	setDate
		ACALL	lcdInit2
		ACALL	calendarOn
		AJMP	$
lcdInit1:
		MOV 	DPTR,#MYCOM
LOOP1: 	CLR 	A
		MOVC 	A,@A+DPTR
		ACALL 	comnWrt
		INC 	DPTR
		JNZ 	LOOP1
		RET
setTime:
		MOV		R0,#60H
		MOV 	DPTR,#MSG1
		ACALL	printMsg
		MOV 	DPTR,#MSG2
		ACALL	process
		MOV 	DPTR,#MSG3
		ACALL	process
		MOV 	DPTR,#MSG4
		;ACALL	process
		ACALL	AMPM
		ACALL	loadTime
		ACALL	clrScreen
		RET
setDate:
		MOV		R0,#64H
		MOV 	DPTR,#MSG5
		ACALL	printMsg
		MOV 	DPTR,#MSG6
		ACALL	process
		MOV 	DPTR,#MSG7
		ACALL	process
		MOV 	DPTR,#MSG8
		ACALL	process
		ACALL	loadDate
		ACALL	clrScreen
		RET
lcdInit2:
		MOV		A,#0CH
		ACALL	comnWrt
		MOV		A,#85H
		ACALL	comnWrt
		MOV		A,#"/"
		ACALL	dataWrt
		MOV		A,#88H
		ACALL	comnWrt
		MOV		A,#"/"
		ACALL	dataWrt
		MOV		A,#0C5H
		ACALL	comnWrt
		MOV		A,#":"
		ACALL	dataWrt
		MOV		A,#0C8H
		ACALL	comnWrt
		MOV		A,#":"
		ACALL	dataWrt
		RET
calendarOn:
	C4:	ACALL	updateDays
		ACALL	updateMons
		ACALL	updateYrs
	C1:	ACALL	updateHrs
		ACALL	updateMins
		ACALL	updateSecs
		ACALL	delaySec
		INC		SECS
		MOV		A,SECS
		CJNE	A,#60,C1
		MOV		SECS,#0
		INC		MINS
		MOV		A,MINS
		CJNE	A,#60,C1
		MOV		MINS,#0
		INC		HRS
		MOV		A,HRS
		CJNE	A,#12,C2
		MOV		A,6AH
		CJNE	A,#1,C3
		ADD		A,#1
		MOV		6AH,A
		AJMP	C4
	C2:	CJNE	A,#13,C1
		MOV		HRS,#1
	C3:	INC		DAYS
		MOV		A,DAYS
		CJNE	A,#30,C4
		MOV		DAYS,#0
		INC		MONS
		MOV		A,MONS
		CJNE	A,#13,C4
		MOV		MONS,#1
		INC		YRS
		AJMP 	calendarOn
process:
		MOV		A,#0C1H
		ACALL	comnWrt
		ACALL	printMsg
		ACALL	readKey
		ACALL	dataWrt
		SUBB	A,#30H
		MOV		@R0,A
		INC 	R0
		ACALL	readKey
		ACALL	dataWrt
		SUBB	A,#30H
		MOV		@R0,A
		INC 	R0
		ACALL	clrLine
		RET
AMPM:	MOV		A,#0C1H
		ACALL	comnWrt
		ACALL	printMsg
		ACALL	readKey
		ACALL	dataWrt
		SUBB	A,#30H
		MOV		6AH,A
		RET
loadTime:
		MOV		A,60H
		MOV		B,#10
		MUL		AB
		ADD		A,61H
		MOV		HRS,A
		MOV		A,62H
		MOV		B,#10
		MUL		AB
		ADD		A,63H
		MOV		MINS,A
		MOV		SECS,#0
		RET
loadDate:
		MOV		A,64H
		MOV		B,#10
		MUL		AB
		ADD		A,65H
		MOV		DAYS,A
		MOV		A,66H
		MOV		B,#10
		MUL		AB
		ADD		A,67H
		MOV		MONS,A
		MOV		A,68H
		MOV		B,#10
		MUL		AB
		ADD		A,69H
		MOV		YRS,A
		RET
delaySec:
		MOV		R2,#15
		MOV		TMOD,#1
AGAIN:	MOV		TL0,#1
		MOV		TH0,#53
		SETB	TR0
		JNB		TF0,$
		CLR		TR0
		CLR		TF0
		DJNZ	R2,AGAIN
		RET
updateSecs:
		MOV		A,#0C9H
		ACALL	comnWrt
		MOV		A,SECS
		MOV		B,#10
		DIV		AB
		ORL		A,#30H
		ACALL	dataWrt
		MOV		A,B
		ORL		A,#30H
		ACALL	dataWrt
		RET
updateMins:
		MOV		A,#0C6H
		ACALL	comnWrt
		MOV		A,MINS
		MOV		B,#10
		DIV		AB
		ORL		A,#30H
		ACALL	dataWrt
		MOV		A,B
		ORL		A,#30H
		ACALL	dataWrt
		RET
updateHrs:
		MOV		A,#0C3H
		ACALL	comnWrt
		MOV		A,HRS
		MOV		B,#10
		DIV		AB
		ORL		A,#30H
		ACALL	dataWrt
		MOV		A,B
		ORL		A,#30H
		ACALL	dataWrt
		RET
updateDays:
		MOV		A,#83H
		ACALL	comnWrt
		MOV		A,DAYS
		MOV		B,#10
		DIV		AB
		ORL		A,#30H
		ACALL	dataWrt
		MOV		A,B
		ORL		A,#30H
		ACALL	dataWrt
		MOV		A,#0CCH
		ACALL	comnWrt
		MOV		A,6AH
		CJNE	A,#1,PM
AM:		MOV		A,#"A"
		ACALL	dataWrt
		MOV		A,#"M"
		ACALL	dataWrt
		RET
PM:		MOV		A,#"P"
		ACALL	dataWrt
		MOV		A,#"M"
		ACALL	dataWrt
		RET
updateMons:
		MOV		A,#86H
		ACALL	comnWrt
		MOV		A,MONS
		MOV		B,#10
		DIV		AB
		ORL		A,#30H
		ACALL	dataWrt
		MOV		A,B
		ORL		A,#30H
		ACALL	dataWrt
		RET
updateYrs:
		MOV		A,#89H
		ACALL	comnWrt
		MOV		A,#"2"
		ACALL	dataWrt
		MOV		A,#"0"
		ACALL	dataWrt
		MOV		A,YRS
		MOV		B,#10
		DIV		AB
		ORL		A,#30H
		ACALL	dataWrt
		MOV		A,B
		ORL		A,#30H
		ACALL	dataWrt
		RET
printMsg:
LOOP2:	CLR 	A
		MOVC 	A,@A+DPTR
		ACALL 	dataWrt
		INC 	DPTR
		JNZ 	LOOP2
		RET
clrScreen:
		MOV		A,#01H
		ACALL	comnWrt
		RET
clrLine:
		MOV		A,#0C0H
		ACALL	comnWrt
		MOV		R2,#16
CLL:	MOV		A,#" "
		ACALL 	dataWrt
		DJNZ	R2,CLL
		RET
comnWrt:										;#!Send command to LCD
		MOV 	LCD,A 							;#!Copy reg A to P1
		CLR 	RS 								;#!RS=0 for command
		SETB 	E 								;#!E=1 for high pulse
		ACALL 	DELAY 							;#!Give LCD some time
		CLR 	E 								;#!E=0 for H-to-L pulse
		RET										;#!return to caller
dataWrt:										;#!Write data to LCD
		MOV 	LCD,A 							;#!Copy reg A to port 1
		SETB 	RS 								;#!RS=1 for data
DELAY:											;#!Delay subroutine
		MOV 	R7,#6							;#!R0 = 2
S11:	MOV 	R6,#150							;#!R1 = 255
S21:	DJNZ 	R6,S21							;#!stay here until R1 becomes ZERO
		DJNZ 	R7,S11							;#!
readKey:
		MOV 	P1,#0FFH						;#!Make P1 an input port
K1: 	MOV 	P3,#0                           ;#!Ground all rows at once
		MOV 	A,P1							;#!Read all colums
		ANL 	A,#00001111B					;#!Masked unused bits
		CJNE 	A,#00001111B,K1                 ;#!Till all keys release
K2: 	LCALL 	DELAY                          	;#!Call 20 msec delay
		MOV 	A,P1                            ;#!See if any key is pressed
		ANL 	A,#00001111B                    ;#!Mask unused bits
		CJNE 	A,#00001111B,OVER               ;#!Key pressed, find row
		SJMP 	K2                              ;#!Check till key pressed
OVER: 	LCALL 	DELAY                         	;#!Wait 20 msec debounce time
		MOV 	A,P1                            ;#!Check key closure
		CJNE 	A,#00001111B,OVER1              ;#!Key pressed, find row
		SJMP 	K2                            	;#!If none, keep polling
OVER1: 	MOV 	P3,#11111110B                 	;#!Ground row 0
		MOV 	A,P1                            ;#!Read all columns
		CJNE 	A,#00001111B,ROW_0              ;#!Key row 0, find col.
		MOV 	P3,#11111101B                   ;#!Ground row 1
		CJNE 	A,#00001111B,ROW_1              ;#!Key row 1, find col.
		MOV 	P3,#11111011B                   ;#!Ground row 2
		CJNE 	A,#00001111B,ROW_2              ;#!Key row 2, find col.
		MOV 	P3,#11110111B                   ;#!Ground row 3
		CJNE 	A,#00001111B,ROW_3              ;#!Key row 3, find col.
		LJMP 	K2                              ;#!If none, false input, repeat
ROW_0: 	MOV 	DPTR,#KCODE0                    ;#!Set DPTR=start of row 0
		SJMP 	FIND                            ;#!Find col. Key belongs to
ROW_1: 	MOV 	DPTR,#KCODE1                    ;#!Set DPTR=start of row
ROW_2: 	MOV 	DPTR,#KCODE2                    ;#!Set DPTR=start of row 2
ROW_3: 	MOV 	DPTR,#KCODE3                    ;#!Set DPTR=start of row 3
FIND: 	RRC 	A                               ;#!See if any CY bit low
		JNC 	MATCH                           ;#!If zero, get ASCII code
		INC 	DPTR                            ;#!Point to next col. addr
		SJMP 	FIND                            ;#!Keep searching
MATCH: 	CLR 	A                               ;#!Set A=0 (match is found)
		MOVC 	A,@A+DPTR                       ;#!Get ASCII from table
		RET										;#!return
;-------COMMANDS LOOK-UP TABLE FOR LCD INITIALIZATION
		ORG		300H
MYCOM: 	DB 		38H,0FH,01H,06H,80H,0
MSG1:	DB		"Set time:",0
MSG2:	DB		"Hour(00~12):",0
MSG3:	DB		"Min(00~60):",0
MSG4:	DB		"AM~1 PM~2",0
MSG5:	DB		"Set date:",0
MSG6:	DB		"Day(00~30):",0
MSG7:	DB		"Month(00~12)",0
MSG8:	DB		"Year(00~99):",0
MSG9:	DB		"             "
;-------ASCII LOOK-UP TABLE FOR EACH ROW
KCODE0: DB 		"1","2","3","/" 				;#!ROW 0
KCODE1: DB 		"4","5","6","*" 				;#!ROW 1
KCODE2: DB 		"7","8","9","-" 				;#!ROW 2
KCODE3: DB 		"*","0","#","+" 				;#!ROW 3
		END
connections:
Where is the LCD pin 3 Connections.
how you have connected your LCD pin3...
send the complete diagram.
There is no crystal capacitor.
you need to add 33pf capacitor to the crystal. See the datasheet.
where is the reset circuit.
Even worse: both signals are shorted to GND.
And the display has no supply and no contrast.
Klaus
Some more mandatory processor signals are floating.
All these "details" are ignored by Proteus. And nobody knows how the real circuit looks like,
this is full connection i have tried out.
The crystal value is 12MHz and capacitors used are of 33pF.
Pin3 of lcd is connected with potentiometer and I have also tried it with connecting the pin3 directly with VCC.
Still getting blank screen.
Can you please tell me about the floating signals which are floating...?
See attached circuit. resistors for keypad connections are required.
There's no resistor connected to keypad in your circuit. Can you please clarify it?
I have connected pin31 with VCC which is mentioned in your circuit but still facing the same problem.
Without knowing how your keypad code works I can't mention how to connect resistors to keypad and I can't read you asm code.
I think the problem is with LCD interfacing and not with keypad because before any input from keypad there are words which are supposed to be displayed on screen.
I know that keypad related issue doesn't affect LCD working but can you explain your exact hardware connections including power supply.
Your code has no comments regarding to the display initialization. This could give us at least an indication of whch lcd controller are the firmware based on, and to check if it matches to the hardware connected.
And what is a particular reason to use asm and 51? It is more expensive and complex than stm8 and iar for example.
The second circuit attached earlier has all the connections which I have done There's none extra connection done by me....I'm providing common 5V Vcc to the circuit...
;-----------------------------{{Author: Mustafa Okasha}}--------------------------------------------#!
;--------------------------{{Project: Digital Calendar 1.0}}----------------------------------------#!
;---------------------------{{System: 8051 microcontroller}}----------------------------------------#!
;------------------------------{{Released at: 21/3/2013}}-------------------------------------------#!
LCD		EQU		P0		//for data pins
SECS	EQU		30H
MINS	EQU		31H
HRS		EQU		32H
YRS		EQU		33H
MONS	EQU		34H
DAYS	EQU		35H
RS		BIT		P2.0
E		BIT		P2.1
		ORG 	0H
		AJMP	MAIN
		ORG 	30H
		ACALL	setTime
		ACALL	setDate
		ACALL	lcdInit2
		ACALL	calendarOn
		AJMP	$
lcdInit1:					//initialises lcd
		MOV 	DPTR,#MYCOM
LOOP1: 	CLR 	A
		MOVC 	A,@A+DPTR
		ACALL 	comnWrt
		INC 	DPTR
		JNZ 	LOOP1
		RET
setTime:
		MOV		R0,#60H
		MOV 	DPTR,#MSG1
		ACALL	printMsg
		MOV 	DPTR,#MSG2
		ACALL	process
		MOV 	DPTR,#MSG3
		ACALL	process
		MOV 	DPTR,#MSG4
		;ACALL	process
		ACALL	AMPM
		ACALL	loadTime
		ACALL	clrScreen
		RET
setDate:                                                    //sets date
		MOV		R0,#64H
		MOV 	DPTR,#MSG5
		ACALL	printMsg
		MOV 	DPTR,#MSG6
		ACALL	process
		MOV 	DPTR,#MSG7
		ACALL	process
		MOV 	DPTR,#MSG8
		ACALL	process
		ACALL	loadDate
		ACALL	clrScreen
		RET
lcdInit2:
		MOV		A,#0CH
		ACALL	comnWrt
		MOV		A,#85H
		ACALL	comnWrt
		MOV		A,#"/"
		ACALL	dataWrt
		MOV		A,#88H
		ACALL	comnWrt
		MOV		A,#"/"
		ACALL	dataWrt
		MOV		A,#0C5H
		ACALL	comnWrt
		MOV		A,#":"
		ACALL	dataWrt
		MOV		A,#0C8H
		ACALL	comnWrt
		MOV		A,#":"
		ACALL	dataWrt
		RET
calendarOn:					//calender starts after initialising
		ACALL	updateMons
		ACALL	updateYrs
	C1:	ACALL	updateHrs
		ACALL	updateMins
		ACALL	updateSecs
		ACALL	delaySec
		INC		SECS
		MOV		A,SECS
		CJNE	A,#60,C1
		MOV		SECS,#0
		INC		MINS
		MOV		A,MINS
		CJNE	A,#60,C1
		MOV		MINS,#0
		INC		HRS
		MOV		A,HRS
		CJNE	A,#12,C2
		MOV		A,6AH
		CJNE	A,#1,C3
		ADD		A,#1
		MOV		6AH,A
		AJMP	C4
	C2:	CJNE	A,#13,C1
		MOV		HRS,#1
	C3:	INC		DAYS
		MOV		A,DAYS
		CJNE	A,#30,C4
		MOV		DAYS,#0
		INC		MONS
		MOV		A,MONS
		CJNE	A,#13,C4
		MOV		MONS,#1
		INC		YRS
		AJMP 	calendarOn
process:
		MOV		A,#0C1H
		ACALL	comnWrt
		ACALL	printMsg
		ACALL	readKey
		ACALL	dataWrt
		SUBB	A,#30H
		MOV		@R0,A
		INC 	R0
		ACALL	readKey
		ACALL	dataWrt
		SUBB	A,#30H
		MOV		@R0,A
		INC 	R0
		ACALL	clrLine
		RET
AMPM:	MOV		A,#0C1H
		ACALL	comnWrt
		ACALL	printMsg
		ACALL	readKey
		ACALL	dataWrt
		SUBB	A,#30H
		MOV		6AH,A
		RET
loadTime:
		MOV		A,60H
		MOV		B,#10
		MUL		AB
		ADD		A,61H
		MOV		HRS,A
		MOV		A,62H
		MOV		B,#10
		MUL		AB
		ADD		A,63H
		MOV		MINS,A
		MOV		SECS,#0
		RET
loadDate:
		MOV		A,64H
		MOV		B,#10
		MUL		AB
		ADD		A,65H
		MOV		DAYS,A
		MOV		A,66H
		MOV		B,#10
		MUL		AB
		ADD		A,67H
		MOV		MONS,A
		MOV		A,68H
		MOV		B,#10
		MUL		AB
		ADD		A,69H
		MOV		YRS,A
		RET
delaySec:
		MOV		R2,#15
		MOV		TMOD,#1
AGAIN:	MOV		TL0,#1
		MOV		TH0,#53
		SETB	TR0
		JNB		TF0,$
		CLR		TR0
		CLR		TF0
		DJNZ	R2,AGAIN
		RET
updateSecs:
		MOV		A,#0C9H
		ACALL	comnWrt
		MOV		A,SECS
		MOV		B,#10
		DIV		AB
		ORL		A,#30H
		ACALL	dataWrt
		MOV		A,B
		ORL		A,#30H
		ACALL	dataWrt
		RET
updateMins:
		MOV		A,#0C6H
		ACALL	comnWrt
		MOV		A,MINS
		MOV		B,#10
		DIV		AB
		ORL		A,#30H
		ACALL	dataWrt
		MOV		A,B
		ORL		A,#30H
		ACALL	dataWrt
		RET
updateHrs:
		MOV		A,#0C3H
		ACALL	comnWrt
		MOV		A,HRS
		MOV		B,#10
		DIV		AB
		ORL		A,#30H
		ACALL	dataWrt
		MOV		A,B
		ORL		A,#30H
		ACALL	dataWrt
		RET
updateDays:
		MOV		A,#83H
		ACALL	comnWrt
		MOV		A,DAYS
		MOV		B,#10
		DIV		AB
		ORL		A,#30H
		ACALL	dataWrt
		MOV		A,B
		ORL		A,#30H
		ACALL	dataWrt
		MOV		A,#0CCH
		ACALL	comnWrt
		MOV		A,6AH
		CJNE	A,#1,PM
AM:		MOV		A,#"A"
		ACALL	dataWrt
		MOV		A,#"M"
		ACALL	dataWrt
		RET
PM:		MOV		A,#"P"
		ACALL	dataWrt
		MOV		A,#"M"
		ACALL	dataWrt
		RET
updateMons:
		MOV		A,#86H
		ACALL	comnWrt
		MOV		A,MONS
		MOV		B,#10
		DIV		AB
		ORL		A,#30H
		ACALL	dataWrt
		MOV		A,B
		ORL		A,#30H
		ACALL	dataWrt
		RET
updateYrs:
		MOV		A,#89H
		ACALL	comnWrt
		MOV		A,#"2"
		ACALL	dataWrt
		MOV		A,#"0"
		ACALL	dataWrt
		MOV		A,YRS
		MOV		B,#10
		DIV		AB
		ORL		A,#30H
		ACALL	dataWrt
		MOV		A,B
		ORL		A,#30H
		ACALL	dataWrt
		RET
printMsg:					prints message on lcd
LOOP2:	CLR 	A
		MOVC 	A,@A+DPTR
		ACALL 	dataWrt
		INC 	DPTR
		JNZ 	LOOP2
		RET
clrScreen:
		MOV		A,#01H
		ACALL	comnWrt
		RET
clrLine:
		MOV		A,#0C0H
		ACALL	comnWrt
		MOV		R2,#16
CLL:	MOV		A,#" "
		ACALL 	dataWrt
		DJNZ	R2,CLL
		RET
		MOV 	R7,#6							;#!R0 = 2
		DJNZ 	R7,S11							;#!
readKey:
		RET										;#!return
		ORG		300H
MSG9:	DB		"             "
		END
the names of function depicts the function performed by them and the messages to be displayed are written at the end of code.
If we believe that the shown code is working in Proteus, the failure might be related to
- wiring faults
- defective parts
- timing problems in LCD code (probably ignored by Proteus)
Turning the contrast pot towards GND should show one line of grey blocks for the uninitialized display. If there's no effect at all on turning the pot, the display hasn't correct supply and contrast connections.
There are still many uncommented code details, e.g. the DELAY duration. If I see right, it's about 2 ms, too short for LCD initialization.
I'm also no sure if it's correct to spend all delay time with E high, because the command execution starts after falling E edge. At least unusual coding.
Other question is if you verified that the processor is executing any code.
What is the minimum delay time required for LCD display?
I'm using JHD162A LCD display.
Longest required delay is 4.1 ms during initialization.
I checked the project and Target default settings is for 33 MHz. You change it to 12 MHz and compile and burn it and use it.
I had changed it to 12MHz before creating hex file and loading it.
