Lcd interface with 89c51
mrarslanahmed
Full Member level 2
gujranwala pakistan
I AM TRYING A HALLO WORLD PROGRAM ON LCD BUT ITS NOT WORKING
I DOWNLOADED DIFFERENT TUTORIALS AND WORKED THE WAY GIVEN IN THOSE TUTORIALS...
MY CODE IS:
ORG 00H
MOV A,#38H
ACALL COMNWRT
MOV A,#38H
ACALL COMNWRT
MOV A,#0EH
ACALL COMNWRT
MOV A,#01H
ACALL COMNWRT
MOV A,#06H
ACALL COMNWRT
MOV A,#08H
ACALL COMNWRT
;_________________________________
MOV A,#'H'
ACALL DATAWRT
MOV A,#'A'
ACALL DATAWRT
MOV A,#'L'
ACALL DATAWRT
MOV A,#'O'
ACALL DATAWRT
MOV A,#' '
ACALL DATAWRT
MOV A,#'W'
ACALL DATAWRT
MOV A,#'O'
ACALL DATAWRT
MOV A,#'R'
ACALL DATAWRT
MOV A,#'D'
ACALL DATAWRT
COMNWRT:
MOV P1,A
CLR P3.7 ;RS
NOP
CLR P3.6 ;READ/WRITE
SETB P3.5 ; ENABLE
NOP
CLR P3.5
NOP
ACALL DELAY
RET
DATAWRT:
MOV P1,A
SETB P3.7 ;RS
NOP
CLR P3.6 ;READ,WRITE
SETB P3.5 ; ENABLE
NOP
CLR P3.5
NOP
ACALL DELAY
RET
DELAY:
MOV R3,#0FH
HERE2:
MOV R4,#0FH
HERE:
DJNZ R4,HERE
DJNZ R3,HERE2
RET
END
CODE WAS TRIED ON PROTEUS...THE DESIGN IS
qwertyuiop415263
Full Member level 4
Pakistan
this is the working code for 89s52. You didnt initialize your ports in the code
ORG 0000H
JMP MAIN
MAIN:
MOV P1,0 // Data Pins of LCD
CLR P2.0 //RS
CLR P2.1 // WR
CLR P2.2 // Enable
ACALL DELAY
ACALL DELAY
MOV A,#0x38
ACALL COMWRT
ACALL DELAY
MOV A,#0x0C
ACALL COMWRT
ACALL DELAY
MOV A,#0x01
ACALL COMWRT
ACALL DELAY
MOV A,#0x85
ACALL COMWRT
ACALL DELAY
MOV A,#'A'
ACALL DATWRT
MOV A,#'B'
ACALL DATWRT
MOV A,#'C'
ACALL DATWRT
MOV A,#'D'
ACALL DATWRT
MOV A,#'E'
ACALL DATWRT
ACALL DELAY
ACALL DELAY
S5:JMP S5
COMWRT:
MOV P1, A
CLR P2.0
CLR P2.1
SETB P2.2
ACALL DELAY
CLR P2.2
RET
DATWRT:
MOV P1,A
SETB P2.0
CLR P2.1
SETB P2.2
ACALL DELAY
CLR P2.2
RET
DELAY:
MOV R5,#50
WAIT0:
MOV R6,#50
WAIT1:
MOV R7,#100
WAIT2:
DJNZ R7,WAIT2
DJNZ R6,WAIT1
DJNZ R5,WAIT0
RET
END
qwertyuiop415263
Full Member level 4
Pakistan
Use terminal mode and use power and ground for 5v and GND respectively. Is your simulation successful?
ark5230
Advanced Member level 3
India
Also see whether common point of C1 and C2 is connected to proper ground.
mrarslanahmed
Full Member level 2
gujranwala pakistan
sir
my simulation did not showed any thing.....
what is terminal mode......:???:
---------- Post added at 00:32 ---------- Previous post was at 00:32 ----------
my new code...
org 000h
checkled EQU p1.0
checkled2 EQU p1.5
RS EQU p2.0
RW EQU P2.1
EN EQU P2.2
jmp start
start:
setb checkled ;CHECK THE LED START LED
acall delay
acall INITIALISATION
ACALL WRITE_DATA
clr checkled
acall delay
jmp start_2
START_2:
setb checkled2
acall delay
clr checkled2
acall delay
jmp start_2
INITIALISATION:
ACALL delay_8US
;MOV A,#00H
;ACALL INIT_LCD
MOV A,#38H
ACALL INIT_LCD
MOV A,#0EH
ACALL INIT_LCD
MOV A,#01H
ACALL INIT_LCD
MOV A,#06H
ACALL INIT_LCD
CHECKBUSY:
SETB P3.7
CLR RS
SETB RW
AGAIN:
SETB EN
CLR EN
JB P3.7,AGAIN
RET
init_lcd:
ACALL CHECKBUSY
CLR RS
CLR RW
SETB EN
MOV P3,A
CLR EN
ret
WRITE_DATA:
MOV A,#'A'
ACALL DATAROUTINE
MOV A,#'A'
ACALL DATAROUTINE
MOV A,#'A'
ACALL DATAROUTINE
MOV A,#'A'
ACALL DATAROUTINE
RET
DATAROUTINE:
ACALL CHECKBUSY
SETB RS
CLR RW
SETB EN
MOV P3,A
CLR EN
ACALL CHECKBUSY
RET
delay:
mov r6,#5
d1:
mov r7,#100
d2:
mov r5,#250
djnz r5,$
djnz r7,d2
djnz r6,d1
ret
delay_8US:
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
RET
end
---------- Post added at 00:34 ---------- Previous post was at 00:32 ----------
please check the coding
i am not sure my coding is well or my simulated hardware.....
---------- Post added at 00:40 ---------- Previous post was at 00:34 ----------
sir
u told me i did not initialised my ports ....."initialising means sending clear to port" and why is it necessary to initialise the ports arent they by default at 0v
qwertyuiop415263
Full Member level 4
Pakistan
When your 89c51 power up all your ports becomes input (Logic 1). To use them for lcd interfacing you have to make them as output(Logic 0).
Terminal Mode is present in the left pane of ISIS. you have to use proper ground and vcc in your circuit in proteus.for this you have to use POWER and GROUND present in Terminal Mode.
your code has errors. Lcd require sometime to execute instructions as it has built in controller. after every command you have to give delay from(100ms to 200ms).
try to use my code its is working one
mrarslanahmed
Full Member level 2
gujranwala pakistan
at the start you wrote
mov p1,0
why did not you wrote
mov p1,#0
whats the difference between the two
---------- Post added at 21:49 ---------- Previous post was at 21:13 ----------
why u finished with endless loop
s5:
jmp s5
qwertyuiop415263
Full Member level 4
Pakistan
MOV A,#32H means load that value to A. If you dont use # it means copy contents from memory location.
I should use MOV A,#00H
because my program was finished ,so to make my controller busy i made endless loop.
mrarslanahmed
Full Member level 2
gujranwala pakistan
is it practically right to end with endless lop.......
i want to display these alphabet on real world .... should i copy the schematic on real world or some thing extra will be needed
qwertyuiop415263
Full Member level 4
Pakistan
It is better to make your microcontroller busy forever. You have to connect the reset circuitry with RST pin. Pin 20 of 89s51 should be ground and pin 40 should connect to VCC.
mrarslanahmed
Full Member level 2
gujranwala pakistan
when i try the code with delays its working perfectly well but when i try to check lcd busy flag status its strucked ....why is that so ...
please help me...:???:
code to check busy status is
busylcd:
SETB P3.7
SETB RW
CLR RS
SETB EN
S5:
SETB EN
CLR EN
JB P3.7,S5
RET
qwertyuiop415263
Full Member level 4
Pakistan
I personally dont use BUsy Flag method, it usually create problems while implementing on hardware.
Qaisar Azeemi
Full Member level 5
Peshawar, Pakistan, Pakistan
are you doing all on proteus or you also did it practically on vero board or bread board? if not then i think your LCD will not respond any thing as i see your schemetic.
mrarslanahmed
Full Member level 2
gujranwala pakistan
i am doing on proteus .... can you suggest me simulation software which is more close to practical world.......
So that i just have to transform my simulated design .....
So that i can avoid hidden complexities
qwertyuiop415263
Full Member level 4
Pakistan
For controller based projects Proteus is best for simulation and that is the reason why proteus is very popular among hobbyists and engineers. Is your hardware working now?
mrarslanahmed
Full Member level 2
gujranwala pakistan
yes.... i have designed a small gadget with connectors at the port ....
that gadget was working with my simple led code which i placed on bread board..... but lcd code is not working
