Dear friends,
I have an application where i am using:
1.pic18f46k80 controller
2.4 line lcd (jhd 204a).
3. mcp2200 usb to serial uart..
Microcontroller's tx rx are connected to mcp2200's rx and tx resp.and the ground is common for uC and Lcd and mcp2200 ,
But uC and lcd are supplied via a different Vcc 5V(main supply) , and the mcp2200 is usb powered.....
The problem comes when i power off then power on the system , the lcd shows the garbage value.
if i reset the controller it works ok ....
The thing is that the mcp2200 which i m using remains connected to the usb device(laptop) and so there is power in the circuit , the Controller shows 2.8 v around it and so does the lcd wen the main application power Vcc is switched off.
When i switch on the circuit , the lcd is not able to properly initialize coz there was already some volts across it....
Please suggest what could be done in order to completely detach the lcd and uC , from mcp2200 usb power supply wen the device is switched off....
Thanks and regards
Jitender
