marduk18
Newbie level 3
PIC 16F877A and using mikrobasic
hi all
Im writing a program to display values from 0 to 999. actually the word 'FLOW RATE=' is displayed first.
Then, when portc.0=1, a value of 0 to 9 is displayed on the 11th column of row 1
When portc.1=1, the cursor shifts to the right, that is, to the 12th column of row 1
when portc.0=1 again, a value of 0 to 9 is displayed at the current cursor position, that is on the 12th column of row 1
sadly, the program is not working as planned on the PIC simulator IDE
please help friends
here's the program
program LCD_trial12
dim k0 as byte
dim text as string [20]
main:
TRISC = 1
TRISB = 0
Lcd_Init (portB)
Lcd_Cmd(LCD_CLEAR)
text = "FLOW RATE="
Lcd_Out(1,1,text)
Lcd_Cmd(Lcd_Underline_On)
k0=0
path0:
for k0=0 to 9
if
portc.0=1
then
gosub augmenter
end if
if
portc.1=1
then
Lcd_cmd(Lcd_Move_Cursor_Right)
end if
delay_us(1000)
goto path0
augmenter:
select case k0
case 0
Lcd_out_cp("0")
case 1
Lcd_out_cp("1")
case 2
Lcd_out_cp("2")
case 3
Lcd_out_cp("3")
case 4
Lcd_out_cp("4")
case 5
Lcd_out_cp("5")
case 6
Lcd_out_cp("6")
case 7
Lcd_out_cp("7")
case 8
Lcd_out_cp("8")
case 9
Lcd_out_cp("9")
end select
delay_us(1000)
next k0
return
end.
hi all
please help friends
here's the program
program LCD_trial12
dim k0 as byte
main:
TRISC = 1
TRISB = 0
Lcd_Init (portB)
Lcd_Cmd(LCD_CLEAR)
text = "FLOW RATE="
Lcd_Out(1,1,text)
k0=0
path0:
for k0=0 to 9
if
portc.0=1
then
gosub augmenter
end if
if
portc.1=1
then
end if
delay_us(1000)
goto path0
augmenter:
select case k0
case 0
Lcd_out_cp("0")
case 1
Lcd_out_cp("1")
case 2
Lcd_out_cp("2")
case 3
Lcd_out_cp("3")
case 4
Lcd_out_cp("4")
case 5
Lcd_out_cp("5")
case 6
Lcd_out_cp("6")
case 7
Lcd_out_cp("7")
case 8
Lcd_out_cp("8")
case 9
Lcd_out_cp("9")
end select
delay_us(1000)
next k0
return
end.
