mugheesnawaz
Member level 1
- Joined
- May 1, 2013
- Messages
- 39
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,605
problem in displaying on lcd is that it slows down decrementing my duty.
unsigned int adc_data[4];
unsigned char analog_selected = 0;
unsigned char str[50];
unsigned short duty1=255;
float form1;
// LCD Module connections
sbit LCD_RS at RD0_bit;
sbit LCD_EN at RD1_bit;
sbit LCD_D7 at RD7_bit;
sbit LCD_D6 at RD6_bit;
sbit LCD_D5 at RD3_bit;
sbit LCD_D4 at RD2_bit;
// End LCD module connections
// LCD Pin direction
sbit LCD_RS_Direction at TRISD0_bit;
sbit LCD_EN_Direction at TRISD1_bit;
sbit LCD_D7_Direction at TRISD7_bit;
sbit LCD_D6_Direction at TRISD6_bit;
sbit LCD_D5_Direction at TRISD3_bit;
sbit LCD_D4_Direction at TRISD2_bit;
// End of LCD Pin direction
void interrupt(){
if (PIR1.ADIF) {
PIR1.ADIF=0; // clear AD interrupt flag
switch (analog_selected){
case 0:
adc_data[0] = (ADRESH << 8) | ADRESL; // read dadta from channel 0
analog_selected++; // increase channel index
ADCON0 = 0b11001001; // select channel 1
break;
case 1:
adc_data[1] = (ADRESH << 8) | ADRESL; // read dadta from channel 1
ADCON0 = 0b11010001; // select channel 2;
break;
case 2:
adc_data[2] = (ADRESH << 8) | ADRESL; // read dadta from channel 2
ADCON0 = 0b11011001; // select channel 3;
break;
case 3:
adc_data[3] = (ADRESH << 8) | ADRESL; // read dadta from channel 3
analog_selected = 0; // return channel 0
ADCON0 = 0b11000001; // select channel 0;
break;
Delay_Cyc(3); //wait acquisition time
ADCON0.F2=1; //start conversion again
// Loop variable
void main(){
unsigned int i=0;
float temp;
CMCON = 7; //Disable ADC Comparators
TRISA=0xFF;
TRISB=0;
TRISC=0;
TRISD=0;
TRISE=0;
ADCON1 = 0x82; // AN0->AN4 selected as analog input 1/FRC 0010 for AN0 to AN4
ADCON0 = 0b11000001; // Configue analog mode
INTCON.GIE = 1; //Enable global interrupt
INTCON.PEIE = 1; //Enable peripheral interrupt
PIE1.ADIE = 1; //Enable ADC interrupt
Delay_us(20); //wait for acquisition time
ADCON0.F2 = 1; //start conversion
//PORTE.F0=0;
//PORTE.F1=1;
CCP2CON= 0x0B; //wait for AD conversion and reset timer
Lcd_Init();
Lcd_Cmd(_LCD_CURSOR_OFF);
PWM2_Init(25000); // Initialize PWM1 for 25Khz
PWM2_Start(); // start PWM1
PWM2_Set_Duty(duty1); // Set current duty for PWM1
while(1)
temp = adc_data[i]; // read data from channel i
//Delay_us(20); //wait for acquisition time
i=0;
form1=((temp*5)/1023) ;
//PORTD = form1; // Send lower 8 bits to PORTD
//PORTC = temp >> 2; // Send 2 most significant bits to RB7, RB6
//form1=((temp*5*10)/(1023)); //i divided buck output by 10 and gave it to AN0
FloattoStr(form1,str);
Lcd_Cmd(_LCD_CLEAR);
Lcd_Out(1, 1, "Battery Voltage=");
Lcd_Out(2, 1, str);
//Delay_ms(10);
duty1-=2.55;
