LCD contrast programmable negative power supply
bobytronic
Member level 2
digital potentiometer lcd negative
I'm looking for a solution to design a programmable negative power supply for LCD contrast with a DC/DC converter
-18V<Vout<0V
Somebody has an idee or an Application note (DC/DC converter)???
Regards
sadat007
Full Member level 4
Pakistan
pwm to dc for lcd contrast
HI,
why not use Digital Potentiometer from Maxim etc.
For -Ve supply for LCD also Maxim good.
OR Opamp with inverting mode, dual supply and input with PWM (from uC) and resistor-capacitor filter to generate -Ve at output.
ash
Full Member level 3
Europe
lcd contrast boost
you can use 7924 for -24v power supply and interface it DAC or digital potentiometer to microcontroller
bobytronic
Member level 2
negative voltage controller 7662
The problem is that i have only +- 15 V power supply !! and i want up to -18V !! ==> BucK Boost converter!!
ash
Full Member level 3
Europe
there was a application note on microchip.com that demonstrates +12v to +170v. If you put inductor in (-) line you would get -170v. I didn't read the article but i think switching time of fet specifies outpul voltage.
sadat007
Full Member level 4
Pakistan
you can also try Doubler (Capacitor+Diode) on -15 if you have +15V,GND,-15V :wink:
cancel
Full Member level 5
hi .. i am using and pwm from avr and some op amps to control contrast
of my lcd via software. If you need higher voltage try icl or maxim 7662 .. it is voltage inverter/doubler in small size and low cost
regards
cancel
robotman
Member level 3
If I remember correctly, Maxim makes a power supply chip that is a boost/invertor with an external digital up/down control. I have used it, but many years ago.
robotman
atomic_ant
Junior Member level 1
cap charge pump with the PWM coming from your uC, ripple can be reduced by putting a regulator at the output.
