layout tricks in standard cells
drabos
Full Member level 6
I am just wondering why in many standard cell library in an inverter layout the gate is not straight rather like a snake. What is the advantage of this structure???
pit1000
In technologies with silicide use of snake shaped gates allows to save the area due to reduction of the areas of a source and a drain and accordingly to reduce parasitic cap.
    drabos
MSSN
Full Member level 3
I think they do so to be able to compact the area as much as possible without violating the layout design rules
    drabos
leohart
Full Member level 4
Hi all
How does this snake look like?
fixrouter4400
Full Member level 4
the reason why they use an angle polysilicon layer..to save area but this is allowed only to a short as possible poly bent to minimise the risk of current leakage.
    drabos
leohart
Full Member level 4
FT...I was wondering why an inverter use snake-like gate...Did drabos talk about an inverter or a poly resistor?The latter case is common,I just cannot image a snake-like-gate inverter...
drabos
Full Member level 6
inverter
yeah, I can't imagine why, too.
