layout problem in CADENCE tool
pgoyal
Newbie level 3
Hello
My design of LNA is working fine when i am running schematic. I am naive at layout drawing in cadence tool. When i draw a transistor from tsmc library it brings out a big transistor say 40u with 8 fingers by default. I had also shorted its source (Ring) to PSUB. DRC is running fine but while extraction
error message "Figure causing multiple stamped connection"
can u please suggest the remedy
TIA
pratyusha
Junior Member level 1
"Multi stamp error ' occurs when all the gnd or vdd connections are not shorted . So check all the gnd connections are shorted or not.
vijay.kumarreddy
Member level 4
Bangalore,India
U will get this type of errors when ur P-sub strate is at different potentials.To avoid this error u need to connect all the substrate contacts to the ground properly.
regards ,
vijay
shiva4u
Member level 1
Which tool you are using for LVS and Extraction. What you meant by LNA.
Thanks & Regards,
Shiva.
crystal
I'm having the same problem with my layout.
How to connect the substrate contacts to ground ? Don't really get it. Can elaborate?
mince
Member level 5
Texas
Use an M1-P contact. Put several of these throughout the substrate to make sure it is at the same potential everywhere. Connect all of them to Vss.
sundeep4u
Newbie level 5
i need ncsu library can u sen it to me
Added after 1 minutes:
or make a link here
