Dubious Drewski
Newbie level 5
So I just recently learned what voltage and amps were, but I'm wondering about something.
If amps are the actual measurement of electrical flow, then why are volts important? Voltage is a measure of the electrical "pressure", right? So as long as there are enough volts to get the electricity through the circuit, then why would you need more than the bare minimum?
In other words: if the electricity isn't going to be jumping across any gaps(not part of a normal circuit, I would hope), then why does voltage even matter if the true power comes from the amount of amps?
Feel free to laugh now.
EDIT: and one more thing: how can you have tons of Volts but very little amps? If there's tons of "pressure" I would think that there would be tons of "backed-up" electricity causing that pressure, which intuitively to me means, high amperage. I'm wrong obviously, but how?
