Hi everyone,
Can I ask a few questions concerning the last few steps of the tapeout. I am using TSMC 65nm PDK.
1. My LVS is all set without sealring. However, it reports errors when I added the sealring...It seems LVS recognize the sealring as some device. Is this my problem when I modify the seal ring or is it one of the TSMC bugs? Is there a sealring appnote I should read?
2. I added the Dummy OD_PO and Dummy Metals but some of the density error persists when I run DRC. Does this mean that I might set the M_fill deck wrong?
3. I exported my design with dummy fills into GDS file and re-run the dummy fill command. In theory, the new generated dummy GDS file should be empty. To my surprise, there are new dummy shapes generated. Is this normal?
Thanks
Al
