LandLack
Member level 3
Dear Community,
I need to use this Laser: http://www.suncityinc.com.cn/IMAGE/pro/PDF/DC-18GHz_DFB_LD_FIN.pdf ; this is the first time, so I want just to be sure:
1)since the input is said to be matched at 50 ohm, and also since the "input-1db-compression-point" is seen as dBm (power) , I don't need strictly to give current on the input, since power should be enough, right?
2)The input signal should enter through the SMA connector, correct?
3) And the DC current should be entering through pad 3, and should be negative since that connector is "cathode" (while the case is the anode), right?
Please, can you control from the datasheets if at least these simple statements are correct. Thanks
Best Regards,
LandLack
Best Regards,
LandLack
