laser sensor OR infrared for distance measurement <50cm
mcwee65
Newbie level 1
UK
Hey,
I need to measure distance <50 cm from a wall... I have been using infrared sensors but they give me a number of reading which are no accurate to the distance.
I have a small amount of knowledge about making circuit boards basically how to solder.
I need to be able to make a circuit with a laser which can measure distance to the wall which is less than <50 cm.
I have done some research and been to my local shop and they asked me to come with a circuit diagram.
Can anybody recommend any sensor which I can use?
Thanks
miredox
Member level 4
Re: laser sensor OR infrared for distance measurement <50
What accuracy do you need? The IR-sensors from Sharp are pretty accurate and have a range of 10-80cm. Example here.
Other possibility is using a laser + webcam, e.g. here. But this is in fact exact the same principle as used in the Sharp sensors, so accuracy will not be better.
For higher accuracy, you can do a phase-shift measurement of the reflected laser beam. For this, you need a fast photodiode and fast analog hardware. Not so easy!
rocksal
Newbie level 1
chennai
hey why dont u use a tsop based sensor
pranam77
Advanced Member level 5
INDIA
Generally for measuring distance, ultrasonic technique works well...Cheers
karesz
EU
Morning mcwee65,
Can you apply some (retro) reflector on your target pls?
K.
karesz
EU
Hi mcwee65,
How is your progress pls?
You can have the semiconductor Laser, what you buyd, but you need a positions sensitive detector (i.e. a Photoresistor) to that...
What kind of precision you need?
K.
