Large Signal Frequency Response
ahmedsalah00
Member level 2
Cairo - Egypt
Hi
I just need to understand the curve entiteled "Large Signal Frequency Response' in the AD620 Instrumentation amplifier datasheet.
my concrete questions are:
1- What are the dashed verticle lines ? G=100 and G=1000
2- What does the phrase "BW limit" indicate in the curve? and why ?
please find the datasheet attached.
  • AD620.pdf
FvM
Super Moderator
Staff member
Bochum, Germany
The Large Signal Frequency Response diagram gives the maximum voltage that can be output due to limited slew rate of the amplifier. The dashed line shows the -3 dB bandwidth limit for different gains, as it't also shown in the gain vs. frequency graph.
RCinFLA
Advanced Member level 2
There is a finite slew rate of the amplifier which limits the bandwidth at larger signals.
ahmedsalah00
Member level 2
Cairo - Egypt
so , we may think of figure 20 as the SOA (safe operating area ) of work ?
FvM
Super Moderator
Staff member
Bochum, Germany
It's not a safe operation area but an area of linear amplifier operation. When the signal is affected by limited slew rate, a sine get's distorted to triangle.
LvW
Advanced Member level 5
Germany
Yes, but note: linear operation is always possible (that means: also for frequencies higher than the indicated BW limit) if the amplitudes remain within the limits as shown in the graph.
---------- Post added at 08:06 ---------- Previous post was at 07:42 ----------
As far as the vertical dashed lines are concerned: These are frequency limits (3-dB BW) caused by the small-signal behaviour of the circuit for two differnt gain values (see also Fig. 19 of the data sheet).
