KST-TX01 and KST-RX806
maha384
Junior Member level 3
Egypt
kst-tx01
Hello
could anyone send me any information or datasheet about KST-TX01 and KST-RX806 modules
thanks
kst-rx806
HI
OK your data sheet :D
I have little experience with it If you need any help
Sokrat
kst tx01
Asslamo 3likom
How do you Evaluate it?
What about the range?
How to select the frequency?
Is there any more details?
What about collision and interference ?
these are the details available form RAM electronnics, is there anything more?
Salam
Hossam Alzomor
kst-tx01
Hi alzomor
1-How do you Evaluate it?
- I used the first version from RAM " without antenna " in small project It work fine
2-How to select the frequency?
- I think no selection for frequency one frequency only available 434MHZ
3- Is there any more details?
- no more details but you must know the datasheet for transmitter is fake the output in not 1W and distance not 1500km the real measured output is -10dbm "using RF prob" and I remember the maximum distance is Four-storey
4-What about collision and interference ?
- not tested until now
Note:
new version from ram "with antenna" the antenna is very bad antenna I recommend design your antenna :cry:
alzomor I will send PM for you
SALAM
kst-rx806
hi
many thanks for your help i will start working with this module and i will ask you if i face any problem ..
kst-rx806 with microcontrollrt
hello
how r u doing?
i want to ask you about an encoder and decoder ICs for these RX and TX
could you please send me their part numbers or suggest some which are working well with these RX and TX
many thanks
kst-tx01 data sheet
Salam aliko
you don't need any encoder IC just connect it with your microcontroller like 8051 and send your data
Note:
don't use serial port "UART" to transmit your data
Sokrat
kst-tx01 kst-rx806 project
hello
thanks for your replay
i want that encoder w decoder chip to make sure that my reciever is the only one who recieve my data
to avoid interference issue
is it possible without encoder and decoder chips?
i don't want to make my code complicated
thanks in advance
kst-rx806 with pic
Ok
first send one byte " without any coding " and received it without error?
to make sure your TX and RX is working !
Sokrat
kst-rx806 using
HELLOW
I M A BEGINNER IN THIS.
I HAVE THE MODULE BUT I BONT KNOW HOW TO USE IT.
CAN U GIVE ME AN CIRCUIR DIAGRAM OF THIS??
using kst-rx806
hello
u will find pin description in the data sheets,just connect it to the uart of microcontroller
tx01 ask schematics
Hi
yes just connect it to your microcontroller IO pin
NOTE:
AT first time I connect this model Transmitter to UART directly but received data was not correct . I think "maha384" don't have good practical experience with this model
I think the best way to good transmit and receive data you should use pulse width not UART . IF you like I can send small program using 8051 to transmit and receive data.
Sokrat
tx-01
hi sokrat
u r right i did't interface this module to microcontroller yet as i was busy in another module but i was planning to try to interface it to the uart ...
but now i will take ur advice in my concideration and will work with IO pins
and could u plz send a simple grpgram to help us
kst-tx01 datasheet
Hi maha384
please find the attachment file include schematic and small program for test but I'm sorry the program is assembly language for TX and RX the program for TX will send from 0 to 9 and RX will display received data on 2*16 LCD . I use proteus for simulation .
what about your antenna ?
Thank you
Sokrat
transmitter module kst-tx01
HI sokrat
I have bought this kit from RAM and iam using it to send 8 bytes of data from pic16f628A to pic 16f877a at baud rate 2400 bit/s
I want to now why I should not interface the transmitter module to the uart and the recevier to the uart too
and is this baud rate fast or i may increase it
and when i put high on the data in the data out from the receiver doesnot keep high, just get high for less than a second and goes zero, are the kit damaged or it is workin fine?
sorry if my question r dump but iam totally new with this kit
plz answer as soon as u can as this project is very important to mee
thanks alot for ur time
transmitter module kst-tx01 data sheet
Hi nettigerman
1- why I should not interface the transmitter module to the uart and the receiver to the uart too?
Answer : this module using ASK modulation if you put oscilloscope on RX pin without transmitter send any data the RX pin will not be 0 or 1 forever but will be 1 & 0 random . try to send one byte and display it on led or lcd etc.. using UART what is results?
please take my code as reference for you .
Thank you
hi all specially sokrat , thank you for your effort really i mean it
unfortunately my friend get the same module but he has not any background of the microcontroller then he asked me for a help and that's bring me here after search and after i found that this manufacture of the module doesn't deserve any one to buy his medule
the datasheet isn't helpful at all so i think i will ask your help :D
1st - the nature of the transmission will be serial or bit by bit so when i transmit logic 1 what is the time period should applied between every bit on the transmitter so that it can handle them correctly and never make interference between them and also the time period on the receiver which after it i know that it is ready for the next bit
2nd - i assume that logic 1 will be 5 v so how can i define the logic 0? will it just 0 v or another voltage state except the 5 v and as example in RS-232 serial protocol the logic 1 is from -3v to -10v and the logic 0 from +3v to +10v as i think it is so what will be the logic 0 voltage value on the receiver
3rd - i never work with atmel mcu so can i ask you to translate your code and just the sequence of the transmitting and receiving 1 byte to any language say flow chart or just describe it so that i can translate it to microchip code which i know very well
at the end very thanks for your time and i hope i hear from you soon
walid el masry
I'm so sorry for late
see your PM BOX ( gotoamr (at) gmail.com)
Sokrat
hi everybody .
can anyone get any decoder&encoder for this transmitter ?
i dont want to use it with pic , thanks .
Al Salmo3alikom
hi everyone
i read the all thread and i just asking if anyone can put an example on how to use it using mikroC
another question : can i use the Manchester code library in Mikro C to do it
thanks in advance
Hassan
