register status
boot status
REGISTER.BOOT_STATUS 00000000000000000000000000000001
REGISTER.BOOT_STATUS.BIT00_0_STATUS_VALID 1
REGISTER.BOOT_STATUS.BIT01_0_FALLBACK 0
REGISTER.BOOT_STATUS.BIT02_0_INTERNAL_PROG 0
REGISTER.BOOT_STATUS.BIT03_0_WATCHDOG_TIMEOUT_ERROR 0
REGISTER.BOOT_STATUS.BIT04_0_ID_ERROR 0
REGISTER.BOOT_STATUS.BIT05_0_CRC_ERROR 0
REGISTER.BOOT_STATUS.BIT06_0_WRAP_ERROR 0
REGISTER.BOOT_STATUS.BIT07_0_SECURITY_ERROR 0
REGISTER.BOOT_STATUS.BIT08_1_STATUS_VALID 0
REGISTER.BOOT_STATUS.BIT09_1_FALLBACK 0
REGISTER.BOOT_STATUS.BIT10_1_INTERNAL_PROG 0
REGISTER.BOOT_STATUS.BIT11_1_WATCHDOG_TIMEOUT_ERROR 0
REGISTER.BOOT_STATUS.BIT12_1_ID_ERROR 0
REGISTER.BOOT_STATUS.BIT13_1_CRC_ERROR 0
REGISTER.BOOT_STATUS.BIT14_1_WRAP_ERROR 0
REGISTER.BOOT_STATUS.BIT15_1_SECURITY_ERROR 0
REGISTER.BOOT_STATUS.BIT16_RESERVED 0000000000000000
REGISTER.CONFIG_STATUS 01000010000100000001101011111100
REGISTER.CONFIG_STATUS.BIT00_CRC_ERROR 0
REGISTER.CONFIG_STATUS.BIT01_DECRYPTOR_ENABLE 0
REGISTER.CONFIG_STATUS.BIT02_PLL_LOCK_STATUS 1
REGISTER.CONFIG_STATUS.BIT03_DCI_MATCH_STATUS 1
REGISTER.CONFIG_STATUS.BIT04_END_OF_STARTUP_(EOS)_STATUS 1
REGISTER.CONFIG_STATUS.BIT05_GTS_CFG_B_STATUS 1
REGISTER.CONFIG_STATUS.BIT06_GWE_STATUS 1
REGISTER.CONFIG_STATUS.BIT07_GHIGH_STATUS 1
REGISTER.CONFIG_STATUS.BIT08_MODE_PIN_M[0] 0
REGISTER.CONFIG_STATUS.BIT09_MODE_PIN_M[1] 1
REGISTER.CONFIG_STATUS.BIT10_MODE_PIN_M[2] 0
REGISTER.CONFIG_STATUS.BIT11_INIT_B_INTERNAL_SIGNAL_STATUS 1
REGISTER.CONFIG_STATUS.BIT12_INIT_B_PIN 1
REGISTER.CONFIG_STATUS.BIT13_DONE_INTERNAL_SIGNAL_STATUS 0
REGISTER.CONFIG_STATUS.BIT14_DONE_PIN 0
REGISTER.CONFIG_STATUS.BIT15_IDCODE_ERROR 0
REGISTER.CONFIG_STATUS.BIT16_SECURITY_ERROR 0
REGISTER.CONFIG_STATUS.BIT17_SYSTEM_MONITOR_OVER-TEMP_ALARM_STATUS 0
REGISTER.CONFIG_STATUS.BIT18_CFG_STARTUP_STATE_MACHINE_PHASE 100
REGISTER.CONFIG_STATUS.BIT21_RESERVED 0000
REGISTER.CONFIG_STATUS.BIT25_CFG_BUS_WIDTH_DETECTION 01
REGISTER.CONFIG_STATUS.BIT27_HMAC_ERROR 0
REGISTER.CONFIG_STATUS.BIT28_PUDC_B_PIN 0
REGISTER.CONFIG_STATUS.BIT29_BAD_PACKET_ERROR 0
REGISTER.CONFIG_STATUS.BIT30_CFGBVS_PIN 1
REGISTER.CONFIG_STATUS.BIT31_RESERVED 0
