ZincBear
Member level 2
high side mosfet switch high power
Hi all,
I am looking for a high power switch (5V, 1.5A or 2A will suffice) that can be controlled by a digital signal of 00, 01, 10 and 11 to switch between powering up 4 devices. Pls see the attached picture.
Each device is identical and requires a fixed 5V, and about 1A to 1.5A of current. My power supply is homemade and is fixed at 5V and max current of 7A. Now, i need to solve the interface between them.
I have tried looking for multiplexers or demultiplexers from TI and analog devices. However MUX and deMUX are usually for digital signals, hence, only low load currents are permitted. 1A is definitely out of the question.
Kindly help!
Hi all,
Kindly help!
