keywords( static, register)
dayal
Member level 3
hi,
can anyone tell me the use of static and register keyword, and also give the example c program.
thanks
dayal
ama_trig
Full Member level 2
Where my hard drive lives!
using register will give you access to register memory (store your variable in register) so you got a way much more faster for frequently access to it, usually compiler will choose to store type/place during its code optimization but using the keyword will override compilers code optimization. you should be looking into you compilers variable storage class
static, depends on where you use, for method-function-variable ... to say simple: I don't understand it well! :D, but what I have seen so far
for variables, if you nest it on highest access possible place, it will act like global and if nested in class type, then you are sharing it true all objects created from it,using one value others will be reference, or when in local scope, will allow local variables to retain their previous value on re-entry to block of code.
