If there is no document, then where are derived layers described ?
Also did you mean converting ltd to slm ? I dont think substrate editor will convert ltd to matl unless I am mistaken.
See below, I literally just took out the dervied mask section and took away the derived mask sections - anything you highlighted.
This seems like it is too easy.
These vias will be merged at a distance of 0.2um - is that correct ?
So now the vias are put back in the stack, but instead of the normal via1 and via2 they are put in the stack as merged vias now.
So to put them back to normal via1 and via2 - would I have to just delete the DERIVEDMASK section, and then change the STACK section to put the original via1 and via2 as they were in the original stack up ? Do I have to account for what the derviedmask section did - ie. the distance it was to grow in the revised stack up.
Here is the potential file I am talking about with modifications I would make, the heights in green I am not sure about.
Also, my Keysight ADS substrate editor only converts to slm and not to subst files from ltd. I can only export to slm - will this help me?
