I have to do analysis of S parameters. Will using a black box give me similar results as an MMIC?If the device is not included in the vendor library list
https://www.keysight.com/main/editorial.jspx?cc=DE&lc=ger&ckey=1490117&id=1490117
maybe you can use a generic black box model
Components-Analog RF > System Models > Amplifiers and Mixers
What type of analysis are you interested in?
I got the .s2p file from Quorvo but it is giving me error.
View attachment 138536View attachment 138536
but this same file is working in PUFF2.1. Am i doing something wrong?
No error in file. as i said its working with another software. not with ADS. Does the file need to be stored in any specific location?
With this error message, it really indicates a problem with the *.s2p file. Can you upload it here?
The best location for *.snp files is the data directory of your workspace. This is the ADS default data path, and the project will work out of the box when the workspace is moved to another computer. If you store to other locations, the full absolute file path to the *.s2p is stored in the S2P data item, and that full path is machine-dependent.
PFA the file (I couldnt attach s2p file so i copied the data and uploaded txt file)
Also i changed the location of the file to C:\Program Files\Keysight\ADS2016_01\tools\lib\Data and it still didnt work
ADS does not like Windows based path names ( spaces,special characters etc) .Put this file under project directory that doesn't include "spaces" in the path name.
The problem is, as indicated, an issue with the s2p file at the line number listed in the error message. It is showing that the problem starts at the last number (S22A) on the last line (20GHz) of the s-parameter file. There appears to be an extra space character at the end of that line for some reason.
