Keil C51 Evaluation Version
The 8051 compiler, assembler, linker, and debugger are limited to 2 Kbytes of object code. Source code may be of any size
h**ps://www.keil.com/download/product/
---------- Post added at 12:36 ---------- Previous post was at 12:34 ----------
And SDCC is an open source Free Embedded C compiler ,
h**p://sdcc.sourceforge.net/
My keil C51 V6.20 CD had corrupted. I had downloaded the C51 V9.05 from h**ps://www.keil.com/download/product/. i had utilized nearly 42k bytes for my project which is done earlier. But this evaluation version had the support upto 2k. while i compile it shows the compiler limit is upto 800H that is, 2048. Can you please give me a solution for this what to do?
Since your project is about 42k ,only option is
try to compile in SDCC a Free Compiler .
---------- Post added at 18:27 ---------- Previous post was at 17:59 ----------
Reads 51
Reads51 v4.2 combines a Small C-compatible 8051 compiler with a relative assembler and linker.
Reads51 Could be used for non-commercial purposes
h**p://www.rigelcorp.com/8051soft.htm
