keil arm7 help in acess memory
kartikkg
Newbie level 5
i am a novice at keil , i am learning arm 7 assembly level program , i want to know hot to read and write into memory ,either rom or ram
AREA ARMex, CODE, READONLY
; Name this block of code ARMex
ENTRY ; Mark first instruction to execute
start
MOV R0,#0X00000000
MOV R1,#0X00000007
LDR R9,[R0]
STR R9,[R1]
END
stop
MOV r0, #0x18 ; angel_SWIreason_ReportException
LDR r1, =0x20026 ; ADP_Stopped_ApplicationExit
SVC #0x123456 ; ARM semihosting (formerly SWI)
END ; Mark end of file
This is my program , but i am unable to edit the memory regions 0x00000000
and this is *** error 65: access violation at 0x00000007 : no 'write' permission
for 0x00000007
sorry for ignorance
bobsanjose
Advanced Member level 1
Silicon Valley
---snip ---
for 0x00000007
sorry for ignorance
Just a thought; did you ever wonder why this area is called READONLY?
Thee are no direct write operations into the ROM or Flash area. Only RAM cells can be written directly.
Writing to FlashROM is called programming and a totally different process.
A couple phrases to use in your favorite search engine
"Difference between ROM and RAM"
"Difference between Code space and Data Space in programs"
You need to cover the basics first. Writing a program in ARM ASM is not the basics.
hth. Bob
kartikkg
Newbie level 5
i know difference between ram , rom etc
what i want is a solution and not a weird lecture which addresses no issue ,
Can anybody who knows for real ,provide me with a solution?
i ve enable rom ram settings in the target device and given them address range too, but yet this problem persists , plz give me clear "instructions"
all the help is greatly appreciated
Added after 1 hours 41 minutes:
can somebody give me a simple way to configure the keil for this , i ve copied the example assembly language pgm from keil software example
