jumping to another loop by detecting which switch is pressed
McMurry
Member level 3
I have four push up button switch.. each pulled up, and also connected to the PortA 0,1,2,3 respectively.
I am making an infinite loop that will detect if any button switch is pressed, like this:
loop btfss porta,0
goto somewhere
btfss porta,1
goto somewhereelse
goto loop
However, the code failed to work.
Anyone may help to explain a correct way to do it?
Re: jumping to another loop by detecting which switch is pre
you probably need some debouncing done with software. (that is if you are not doing it somehow with hardware)
I am not a PIC guy so I can't help you with your code, HOWEVER, I usually do it this way:
Loop:
check if port0.0 = low, if not go to Next
wait delay 50mS
port0.0 = low, now wait here until its high (button released)
jump to a subroutine
Next:
check if port0.1 = low, if not go to Next1
wait delay 50mS
port0.1 = low, now wait here until its high (button released)
Next1:
check if port0.2 = low, if not go to Next2
wait delay 50mS
port0.2 = low, now wait here until its high (button released)
GOTO Loop
if you still can't get it, search Google for "debouncing" or "keypad"
you will get your answer.
Good Luck
